Using FEL to hang lights
   / Using FEL to hang lights #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I've found so many uses for a tractor since I got mine that I'm now expecting a new use every day. The latest thing that I'm considering using my CUT with FEL for is as a man-lift to hang christmas lights.
My CUT is pretty small, so the bucket will only go about 6 feet high. The reason that I'm considering it is because I can put the bucket out over the bushes and hedges where it is difficult and precarious to use a ladder.
Is this insanely stupid? Are there precautions or potential hazards that I am missing here or that I need to plan for?
   / Using FEL to hang lights #2
There are hazards with everything, and while the FEL isn't a "man-lift", it is often used as such. Insane? depends on your definition. Risky? yes, because if done alone you have to crawl into and out of the bucket.
With a good operator at the controls, I would be in the bucket. Or if I had someone to get in the bucket, I'd operate the controls. Takes two to trust each other and not make a 'stupid' mistake where both regret the idea.
(I've told the story where I was on top of a 40' extension ladder that was placed in a small Int'l tractor bucket so I could paint the side of a 50' barn. The bucket moved and I came down, ladder and all, but didn't get hurt. Did that when I was 16.)
Hope you can do it safely. There have been threads here on 'platforms' built around the bucket to make a working area, but they still require someone to position the bucket, IMO. Be careful, for all of us. /forums/images/graemlins/wink.gif
   / Using FEL to hang lights #3
"Is this insanely stupid?"
Probably...but I'm sure you're not the first one to do it. Under the right circimstances, I might too!
"Are there precautions or potential hazards that I am missing here or that I need to plan for? "
A sudden drop by the bucket...whoever is sitting in the seat better know what they're doing! Also, it's one thing to be raised by the bucket, but being transported with that bucket in the air might be the most dangerous part...I wouldn't do that.
Thanks for the replies. I agree that transporting someone in the bucket is insanely stupid.
My brothers and I hang the lights on my Grandpa's house every year on the Saturday after Thanksgiving. There are two spots where he has bushes around the front of his house such that it makes getting a ladder in there very precarious. After reading the replies, it sounds like the FEL, though risky, is less risky than the alternative.
Good advice about the sudden drop in the bucket, Roy. I think I'll be at the controls. None of my brothers is familiar with this tractor and I don't want one of them "guessing" wrong which lever to push when I tell them to lower me down a bit.
   / Using FEL to hang lights #5
I did some work from a bucket back when. The biggest problem for me was the shaky platform. There was considerable movement from all the linkage points adding up. Of course that was on an old, well used machine.
Harry K
   / Using FEL to hang lights #6
We always used the bucket for a lift when I was growing up. Picking pears from our antique pear tree comes to mind. My father is very cautious, so it didn't seem like a big deal.Since I bought my Kubota I use it anytime I need to get on my roof; I put all my tools and materials in the bucket, raise it up to it's full 6+ feet, then place a ladder against the arms to climb up. The only risk is if the hydraulics fail, then I'd go for a ride in a hurry; but after having a ladder kick out as Iwas climbing onto a 2 story roof, I'd much rather step off from the bucket than a ladder.
The only risk I can
   / Using FEL to hang lights #7
My money would say you would more likely get hurt on a ladder than your loader.Like was said a good operator,you can trust.if possible try not to drive straight in to the building,a slight angle might avoid a pinch point,or hitting the building. Id try to drive parrell to the building if i could still reach.I would have the operator try to stay on the tractor at all times to hold the brake.Low idle also to avoid quick loader movements.
I tryed to put the kids trampoline back in the box ,last weekend,put a piece of plywood,on the tilted back fel.so i could slide it into the overhead door of my shed.It was 2 ft lacking being able to do it.Next spring im going tobuild a "riser" to put in the fel so i can accomplish this.
At the companys ive worked at,we always had a 6 ft high box to stand on to do carpentry work,because the fork trucks couldnt get us high enough.A no no today by osha standards,we survived it though.
work safe, work smart
ALAN
   / Using FEL to hang lights #8
</font><font color="blue" class="small">( Is this insanely stupid? Are there precautions or potential hazards that I am missing here or that I need to plan for? )</font>
Insane? naa.. I'm sure (cough) there are quite a few of us who do it.. that is.. get int he bucket and then direct the wife to 'lift'.. I've done it when putting up a tarp / tube frame canopy...
I'm sure that an osha inspector might pass out seeing that sort of thing.. but then.. I figure every time I climb on my tractor.. my risk level went up a color bar anyway.. /forums/images/graemlins/wink.gif
( do be carefull )
Soundguy
   / Using FEL to hang lights #9
I'm not a big fan of using a front end loader as a man lift. A couple of years ago someone did that changing light bulbs at the fire station. Needless to say the operator moved the joystick in the wrong direction and dumped the contents of the bucket ( including the guy changing the bulbs) onto the floor. Thankfully he wan't hurt. When I was a teenager myself and my cousins used to get lifted up in a backhoe bucket to pick grapes off the vines. We thought this was cool, but i wouldn't put my daughters in a bucket to do the same thing. I guess as we get older we get smarter. ( I hope!!!!)
   / Using FEL to hang lights #10
Yep, doing that is stupid and dangerous. Having said that, I use my FEL to hang my Christmas lights every year. It works well to span the shrubs around my house. I have also tried this method to trim a tree branch and did not feel safe doing it; so I stopped. Hanging Christmas lights is about all I would do while standings in the bucket.
UNUSED AGT MX MRT14 STAND ON SKID STEER (A51247)
UNUSED AGT MX...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
1969 Ford Continental (A51694)
1969 Ford...
