Using backhoe to transplant bushes
   / Using backhoe to transplant bushes #1
RocketJSquirrel
Bronze Member
Illinois
JD 755
I want to transplant some large bushes that are about 10-12' wide and tall. This is a quick and dirty job, using a construction size backhoe. The bushes are nasty Russian Olive, which are like a weed in this township. I want to pull some out that are in the way, but I want to see if I can stick them back in along a road boundary for privacy. If they die, it's no big deal, as long as I didn't have to do a lot of handwork in the process. I have already pulled and disposed of several. The backhoe is big enough that it can just scoop them out in one move. What should I do to give them a chance to survive? I know I should have the new hole ready. Should I cut the bush down to size first? Should I dig around the base and cut roots before yanking them out? The more work I have to do, the less enthused I am about the project. But, I want to give them a chance to live. Any suggestions?
   / Using backhoe to transplant bushes #2
RocketJSquirrel, Well, given your requiremens for reduced hand work, make a hole, dig 'em up, drop 'em in.
To increase the odds of survival, give them a good dose of vitamin B solution from your local nursery supply to suppress "root shock."
If you want that privacy while you are still young enough to enjoy it (read, to stimulate growth) get some tree/shrub fertilizer pellets (mine are about an inch thick and an inch and a half in diameter). Take a hoe handle or something and make a hole down into the root mass, drop in a "tablet" and ram it home with the thing used to make the hole. Do not use regular tree spikes (big chunks of fertilizer with a pointed end to eae insertion as they are to "hot" for a transplant, to my way of thinking.
If you dig a slightly larger hole than the size of the chunk of tree containing dirt, you will end up with a slight depression that will aid in watering without having to do manual labor of making a watering ring of dirt around the transplanted tree.
Next step up in the continuum of hand work is to lightly prune it back to reduce the foilage area commensurate to the root loss. Even if you get most of the roots it is likely that the forces involved will have broken off a lot of the root hairs and reduced the roots funtionality until regrowth takes place.
Best of luck to you and plese report back on your results.
Patrick
   / Using backhoe to transplant bushes #3
Don,
Seems like I do this every weekend.. The most important part is the new hole prep. dug 2 x from what your moving in.
Add composted cow manure, compost, and or organic material to allow the roots to start again. Then water like heck for the first month or so to get the roots re established in the ground.
Depending on the plant and root system, you can also pull then out with a nice root ball attached then just put em in the new hole.
The right soil and frequent water makes the most difference.
Carl
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
2011 DODGE CARAVAN (INOPERABLE) (A53843)
2011 DODGE CARAVAN...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
Dump body (A52377)
Dump body (A52377)
