Using a winch as a hoist
   / Using a winch as a hoist #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
Does anybody know how to translate a winches line pulling capacity would translate to lifting capacity? I know that most winches are rated for a rolling load which is significantly more (less?) than what it could lift.
   / Using a winch as a hoist #2
Nope. Also, be prepared for a bunch of comments regarding overhead lifting, safety, etc.... ;)
   / Using a winch as a hoist #3
Are you sure you want to do that? Make sure what you have that pully hooked to will hold up to winches capacity or you could pull down a rafter. I normally wouldn't have posted this but Moss's comment kind of "made me do it".. : )
But it is true.. make sure you have very good cross beam that the hoist pully is attached to!
I do not know the answer to your question though.
   / Using a winch as a hoist #4
You are totally overthinking this. Think about this. The winch does not know vertical from horizontal. All it knows is exerting a force. So,,,, if it's an 8,000 winch, that's it's maximum ability, vetical, horizontal, whatever.
Not quite. They rate winches for rolling loads which is totally different from lifting a load.
   / Using a winch as a hoist #6
The only winches I've seen with rolling load ratings are some boat trailer winches. I think that was to give the buyer an indication of how heavy a boat it could load on a trailer with rollers.
Bruce
   / Using a winch as a hoist #7
Nope. Not sure where that even comes from. I currently use 4 winches under extremely difficult situations. When I'm hanging on a vertically steep cliff on-cable I take comfort in knowing the winch doesn't get freaked out about it. :)
   / Using a winch as a hoist #8
Something to consider is that most overhead winches have a brake to hold the load.
With a boat or ATV winch, when you let go of the "Up" button the spool has nothing stopping it from succumbing to gravity at high speed!
I have tested this for myself in my younger days :shocked:
   / Using a winch as a hoist #9
Are you a good winch or a bad winch ? Chainfall or come-along if you are in a bind. You need a positive brake and detent.
   / Using a winch as a hoist #10
^^Correct^^ I run a 2-ton ARO hoist.
New/Unused H15R Mini Excavator (A44391)
New/Unused H15R...
NEW HOLLAND C185 TRACKED SKID STEER (A45046)
NEW HOLLAND C185...
2014 Volkswagen Passat Sedan (A42744)
2014 Volkswagen...
2013 HINO CONV. ICE CREAM TRUCK (A45046)
2013 HINO CONV...
2018 International WorkStar 7500 AquaTech B-15 Combination Sewer Jetter Vacuum Truck (A44571)
2018 International...
Entyre Chip Spreader (A44391)
Entyre Chip...
