Disc Harrow Using a Tufline disc harrow with a Simplicity Garden Tractor
   / Using a Tufline disc harrow with a Simplicity Garden Tractor #1
Ebie
Parma, Michigan
None
I have a 27 HP Simplicity Prestige Garden Tractor. The engine is rated at 725 cc. I am looking at a Tufline Disc Harrow I would like to use with my tractor. The disc harrow has 16 " notched blades. It has 8 discs and cuts a swath of 52". Weighs about 350 pounds. Does anyone have experience with a garden tractor like this pulling a disc harrow? I don't want to buy this thing and have trouble with traction when pulling it.
   / Using a Tufline disc harrow with a Simplicity Garden Tractor #2
You have a diff lock on that tractor and plenty of power. Good R1 tires on the rear, or chains will help with traction. So will loaded tires or weights. I have pulled quite a few different attachments with various JD garden tractors of the same size as your Prestige in the past with a lot less HP. They will pull a plow through unturned soil fairly well, so that small disk shouldn't be a problem.
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
John Deere 6175M (A50120)
John Deere 6175M...
Feed Bin (A50515)
Feed Bin (A50515)
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
City of Tampa (1611) VIN: 1FTMF1CM1EFB40793, **Title MUST be transferred into buyer's name (A51692)
City of Tampa...
