Using a synthetic engine oil?
   / Using a synthetic engine oil? #1
shooterdon
Elite Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2020 Kawasaki Mule SX; 2021 Bad Boy 54" ZT Elite
Just bought a JD 855 made in 1988. I was wondering if a synthetic oil is a good idea or should I stay with an oil for deisel engines?
I live in northern Michigan where temperatures can swing between -35 and 100. 哲ormal temperatures that I would be using the machine are 15-85. I was thinking about using 0W40....any thoughts?
   / Using a synthetic engine oil? #2
for year round use I'd use Rotella T6 5w-40, it is a synthetic;
other wise a good quality 15-40 diesel rated oil.
   / Using a synthetic engine oil? #3
2nd above suggestion. use it in everything 4 stroke
given your location, would choose T6 5/40 for the cold starts alone.
in 30 degree weather i once changed engine oil on tractor (rotella 15/40) pouring in the very sluggish new oil (same) i promised myself synthetic is the way to go. esp in your climate
   / Using a synthetic engine oil? #4
I live just N/W of you, west of Vanderbilt. I use normal dino 15W40 [ Delo or Rotella from the Wally ] in all my diesels, but I also park all my stuff inside. I did a quick look, and I think your 855 is direct injected... and should start fairly easy. A lot of the indirect injected motors need a cycle on the glow plugs and a little cranking to make them fire even in the warm months. If you are going to park it outside in the elements, you might want to go synthetic. But parked somewhere inside you probably DO NOT HAVE TO HAVE it... Which means it's still up to you. Enjoy...!!! :)
Hello neighbor!! Thanks for the advice!
It will be stored indoors.
   / Using a synthetic engine oil? #6
Rotella is a good oil but not a full synthetic. It's group III hydrotreated.
Ralph
   / Using a synthetic engine oil? #7
I use 5w30 diesel oil in both my tractor and diesel generator. Can only get it at the local VW dealership. You might price it there. May be less expensive than Rotella. They're both hydrotreated "synthetic" group III oils.
You can get a M1 5w30 ESP at Pep Boys, otherwise online, but it's more expensive than the Castrol. It's full synthetic group IV oil.
Ralph
   / Using a synthetic engine oil? #8
Valvoline Premium Blue extreme 5W40 is another good synthetic oil - available at TSC stores. Slso approved by Cummins, so you know its top quality.
   / Using a synthetic engine oil? #9
what is the price out your way for your oil described above?
T6 @ wal is around $22, o'reilly wants $29, quite a difference.
   / Using a synthetic engine oil? #10
I swear by Mobil 1 5-40 full synthetic for the temps we have here in Maine BUT, if I bought a 20-30 year old tractor I would not use it unless I knew it was used for the life of the tractor, I would stick with a good quality 15-40 oil, use a block heater and make sure my glow plug circuit was robust.. It's my opinion that older more worn machines that were built when conventional oil was what they were designed to use should probably stick to the oil grade of the time.
There is debate after debate on this, this is just what I would do..
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
