///// using a rollback truck as a dump truck / hauler /////
   / ///// using a rollback truck as a dump truck / hauler ///// #1
Andyinchville2
Ford 8n
Hi
I need a heavier duty vehicle to move some of my construction equipment
I know it's customary to use a dump truck for this but I also do other work that requires a flatbed and or hauling vehicles here and there so I'm thinking the ultimate vehicle for me might be a modified rollback truck
I'm looking for a heavy duty rollback with a steel deck with removable siding so it can act as a flatbed but at the same time I do need it to dump so I'm wondering and I've actually seen this somewhere where a person had a removable section off the back of the rollback maybe three or four feet maybe longer I didn't see it in person but I'm thinking if that part could be removed and if somehow a longer cylinder in the front could be install then I think I could almost use a rollback truck as a dump truck when needed and also have it set up to tow my trailer with equipment on it
I didn't want to have to buy multiple trucks I was hoping to have one truck to do multiple tasks
Has anybody ever heard of such a thing being done basically using a rollback as a dump truck also?
In order for me to haul my equipment trailer I think I would have to buy one without the wheel lift on the back so I can rig up a heavy duty
Anyways thanks for any and all help on this I know crazy idea LOL
   / ///// using a rollback truck as a dump truck / hauler ///// #2
Or maybe something like this with different bodies/platforms. Lots of pictures at the link:
Bruce
   / ///// using a rollback truck as a dump truck / hauler ///// #3
Would a roll back dump at a steep enough angle to get the dirt to slide out?
   / ///// using a rollback truck as a dump truck / hauler ///// #4
A roll back function will not be able to dump truck no matter how you play with the cylinders. It's the long overhang past the rear axle that makes a rollback do it's thing and dump trucks are completely opposite with very little to no overhang past the hinges that are generally directly behind the rear leaf spring support.
A hook lift like mentioned above are great but you'll really want a second flatbed body along with a dumpster type body for a dump truck type use.
Another problem with them is the roll off mechanism is heavy and really subtracts from a legal load.
I had one on an f 750 and iirc about 6 ton was all we could legally haul with a 33k gvw.
A tandem setup would be sweet.
BUYERS PREMIUM ON EACH LOT # (A43003)
BUYERS PREMIUM ON...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
2023 EAST TEXAS TRAILER (A43004)
2023 EAST TEXAS...
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A42742)
2017 Bomag BMP...
13'x20' Single Garage Metal Shed (A44502)
13'x20' Single...
DITCH WITCH FX30 HYDROVAC TRAILER (A45333)
DITCH WITCH FX30...
