Using a MIG welder to cut closed cell foam
   / Using a MIG welder to cut closed cell foam #1
jwmorris
Veteran Member
Not really a welding subject but another use for a MIG welder.
Not sure why the video went crooked but you can get the concept anyway.
   / Using a MIG welder to cut closed cell foam #2
Couldn't seem to get the video to play. Are you using the welder as a power supply to heat a cutting wire? When I was building RC sailplanes with foam core wings we used a lamp dimmer fed from an isolation transformer to heat a wire stretched on a bow. We followed a Formica template pinned to the foam.
   / Using a MIG welder to cut closed cell foam #3
How long did it take you to get the heat set just right so it didn't just melt the wire
   / Using a MIG welder to cut closed cell foam #4
set up a fan to blow the smoke away from you.
Bruce
Just a second. The wire feed is set on 0, and voltage turned all the way down, gas off. Pull trigger and turn voltage knob up until it's glowing and go.
   / Using a MIG welder to cut closed cell foam #6
That is pretty darned clever. Thanks for sharing both the video and the "how" you did it.
   / Using a MIG welder to cut closed cell foam #7
Very cool as usual - can't wait to see your next vid, "A Custom rip fence for my MIG"... :D ...Steve
   / Using a MIG welder to cut closed cell foam #8
The video worked for me. Very interesting. My MIG will still push wire at the 0 setting,
and I do not have infinite current control. But, my Miller buzz-box does. I should
try that, maybe with some NiChrome wire I have.
I used to be in the ICF biz, and we used all sorts of cutting methods for EPS foam: hot-wire
cutters, chainsaws, routers, recip-saws, even heating elements.
Thx for posting.
   / Using a MIG welder to cut closed cell foam #9
I needed to cut foam boards to make sign lettering.
I used nichrome wire* that I scavenged from an old drier element.
Made up what looked like a wooden 'C' so that I could string the wire vertically between 2 porcelain stand offs.
I had left extra coils of the element strung out along the top of the upper arm as I was not sure of what length of element would provide the exact heat setting.
Power was from a 12 volt battery using clips for contacts. Heat adjustment was moving the clip along the coiled element until the appropriate setting was found.
Cutting the foam with heat seals the pores for a nice smooth finish ready to take paint.
I primed with water base primer and top coat with glossy enamel.
After 8 years of exposure those letters still looked just great.
While most folks don't know it, many large sign lettering is foam cut and glued to building facades.
Some city bylaws demand 3-D lettering and this is one easy cheap way of complying.
* nichrome as it withstands heat without melting while copper generally will when it gets hot enough.
   / Using a MIG welder to cut closed cell foam #10
A nifty idea but you might want to post your video on Youtube since it won't work on photobucket for some of us.
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2015 FORD F550 XLT SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XLT...
UNUSED LANDHONOR FW-13-15000G HYD WINCH (A54757)
UNUSED LANDHONOR...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
