Uses for metal straps?
   / Uses for metal straps? #1
raykos
Central Pa.
JD2305
Started building a tractor garage/workshop. The delivered lumber was held together with metal straps, width sizes approx. 1/2", 3/4", & 1 1/2".
After cutting them to release the lumber, I began to wonder, are there any other uses for these metal straps? Has anyone used them for anything else?
   / Uses for metal straps? #2
They make pretty good shims. I have made a bunch of slim-jims for opening cars and trucks with keys left inside. big dan
   / Uses for metal straps? #3
You can also cut them into about 6" lengths and then shape the ends to make profile scrapers for wood working.
Mike
   / Uses for metal straps? #4
If your nailgun will penetrate them you can use them for hurricane clips i.e. to tie the roof to the walls.
   / Uses for metal straps? #5
Cleary buildings uses them in a few spots to tie in roof braces. On the shop I'm building, the 4 or 5 "jack braces" between the first and second trusses on each end use sections of the steel strapping nailed to the brace 2x4, around and nailed to the truss to tie them together. Otherwise, one wind direction would just pull the brace off of the nails.
   / Uses for metal straps? #7
I don't cut mine any shorter than what they are after you remove them. I put them in my short iron stack and use them as I need them. I've used them mainly for shim stock and strapping as others have mentioned.
Jay
   / Uses for metal straps? #8
ditto that.. great shims.. I've cut them into strips to be used on axle splines as hub shims when money was tight and hubs were loose.. :)
soundguy
   / Uses for metal straps? #9
we used to "weave" the 1/2 & 3/4 stuff to make kendo armor back in college.
hurricane straps
fillet/foam knife (1.5" stock, because it's enough thicker)
reinforcing strip for holsters (sandwich between layers of leather)
I've never seen a nail gun that would go through the strapping, but have drilled it - but my favorite is using a whitney punch to put holes in it.
   / Uses for metal straps? #10
Well.. darn it.. there goes my next years supply of strapping .. I'll have to make some of that armor.. :)
soundguy
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
NEW Woods Reverse Rotation 5ft Tiller (A55218)
NEW Woods Reverse...
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
