Used wood splitter, I've been had....
   / Used wood splitter, I've been had.... #1
familyman
Platinum Member
Perkiomenville, Pa
Kubota L3800HST
I just picked up a used "Performance Built" (Lowes) 13 ton wood splitter.
No wear on it, it's been sitting in the back of a guys workshop for years, unused (he bought it as a backup)(he said).
Fluids are as clean as new. Started right up, ram actuates and returns.
Drove it home, put in a 6" piece of ash... ram stops cold. Motor loads up a little but it barely makes a dent in the wood.
Is it possible that something simple like a pressure relief valve is acting up?
   / Used wood splitter, I've been had.... #2
Yes it could be a system relief or something in the hi- lo circuit stuck
simple things first. Confirm the pump shaft is spinning when under load. Possible if never used a key fell out when installing the drive coupling
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
2018 Mitsubishi Mirage ES 4D Hatchback (A53117)
2018 Mitsubishi...
