Used Rorotiller - what should I check?
   / Used Rorotiller - what should I check? #1
easygo
Veteran Member
Maine
Kubota B7800
Hi all,
I'm considering buying a used 42" Howard tiller. I don't know anything about 3ph tillers so I would need some pointers what to check on it. Unfortunately the ground here is frozen solid so a "test drive" is not possible. I read that it is a reliable brand, but how do I check it for wear&tear? The owner said that it is probably over 10 yrs old, but he is uncertain of it's age. Anyone have a picture or past experience with these?
Easygo
   / Used Rorotiller - what should I check? #2
I don't know about the Howard, but some .things to look for on any tiller are, does it have a slip clutch are the tines worn,does it look abused.turn the pto shaft back and forth to see if there is much slack in the chain or gears
Bill
   / Used Rorotiller - what should I check? #3
Hi all,
Easygo
Don't own a Howard. My rototiller is a used 48" Yanmar RS-1200 that I bought in 05 for $300.
Solex is the local distributer around here
Our Products - Howard - HR7 Rotavator
The Howards look good. Spare parts appear to be available.
Thank you for the suggestions.
Hooked-on-hp:
I may not have the option to hook it up to the tractor so the idea of checking the play in shaft is helpful. It does have a slip clutch.
Flusher:
I would love to get any tiller but most used ones that come up for sale in this area are way too big for my tractor and my wallet. This would just cover the tracks of my rear wheels and I read here that it is an important consideration.
   / Used Rorotiller - what should I check? #5
check the bearings on the main shaft. There should be no play when you push/pull on the main shaft that the tines ride on. a lot of tillers use a chain drive system. I would not be afraid to open it up and see what condition the chain and sprockets are in. If it has offset ability make sure it can be moved to offset position. Check the depth adjustment (if any)
   / Used Rorotiller - what should I check? #6
all these checks are done with out running, but will be easier if you can mount on 3pt hitch and pick it up
1. check for slop in u joints
2. just observe slip clutch for signs of burning or other abuse, if you buy it you can disassemble and setup per the manual later.
3.how much wear on tines, if about 2/3 worn they will need replacement.
4. check for main shaft bearing wear, up/down , end to end, 1/8"+ will need to replace.
5. drain gear or chain case and look for filings and metal in oil and bottom of drain pan
6. open case or look into case thru plugs etc.
A.if gears look for grooving,scratches etc. on drive side of tooth face, if flat surface on top of tooth is no longer visible (ie; just a point and not flat) gears are shot and will need replacement unless you only going to use for just a garden once or twice a year.
B.if chain look at sprocket teeth, if drive side of tooth is convex on the drive side and looks like the back side (or slack side)they are ok, if they are starting to take on a concave hooklike to the face and the chain is very sloppy and has no more adjustment, then you will need to replace chain and sprockets. Always replace the chain and sprockets together or the new part will have a much shorter life.
Good luck.
Joe,
Thank you for the detailed descriptions. I will do my best to check it out hopefully this weekend.
It would be used on the occasional bases for ever increasing home garden, so slightly scary looking piece would probably still serve me for years and years.
2024 Apex Hyperdisc T20 High Speed Tiller (A44789)
2024 Apex...
2011 WESTERN STAR 4900EX (A45046)
2011 WESTERN STAR...
2025 JMR 66in Hydraulic Grapple Bucket Skid Steer Attachment (A42742)
2025 JMR 66in...
1998 Volvo VN Truck, VIN # 4VA7BBJF2WN759933 (A44391)
1998 Volvo VN...
2016 Ford F-150 Pickup Truck (A42744)
2016 Ford F-150...
2007 Volkswagen Rabbit Hatchback (A42744)
2007 Volkswagen...
