campman63
I have a 500 gallon used oil tank on skids that i want to clean out and store diesel in what do i need to do to clean tank out . thanks
Why kind or type of oil was in the tank?I have a 500 gallon used oil tank on skids that i want to clean out and store diesel in what do i need to do to clean tank out . thanks
Then you shouldn't have any microbes growing like a fuel oil tank w/ a water layer at the bottom would have developed. If there is no 'heel' of the old oil in the tank you should be fine to just set it up for the diesel. Maybe flush a few gal of diesel through to make sure there is no particulate debris...motor oil and hydraulic fluid
