Used M7040
   / Used M7040 #1
dlauffenburger
Warren PA
JD 5425 w/542 Loader
I am looking at a used 2006 Kubota M7040 over the internet and am curious if there is some place on the net that shows the specs of a 2006 or what has changed in the model since then. I have researched the 7040 but everything i have seen is for the current production model which may or may not be what is on the 2006.
Are there any issues with the M7040 tractors? I have seen a couple of post talking about a hydralic issue but am not sure if it was an isolated case or a model problem.
Any thoughts or comments?
Thanks,
   / Used M7040 #2
If he doesn't show up, check with Builder as he has a 7040 he bought used and uses commercially.
   / Used M7040 #3
   / Used M7040
Hrcarver,
Thanks for the link.
Dave
   / Used M7040 #5
They are very consistant with specs from 06 to current!
   / Used M7040 #6
Art, the newer models (not sure what year the switch was, I believe 08 or 09) are heavier than the first ones. I want to say around 800 lbs heavier. Also slight hp gains. You are right, mostly the same though.
   / Used M7040 #7
I doubt that the new M7040 is 800 lbs heavier than the 2006 model, but I could be wrong. Do you know what they changed to add 800 lbs? I believe that Kubota did add a turbo to the newer models, primarily to meet emissions requirements.
   / Used M7040 #8
The kubota with a cab m6040 went from 4650 to 5450lbs. I dont know about the 7040.
   / Used M7040
HRCARVER,
I contacted Kubota HQ and they sent me the spec sheet for the 2006 M Series.
  • 2006 M7040 Specs from kubota hq.pdf
   / Used M7040 #10
HRCARVER,
Thanks, the weights are different than I thought.
Who did you contact? I'd like to know the weight with the cab.
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2002 International 9200i Truck (A51039)
2002 International...
EZ-GO GOLF CART (A51243)
EZ-GO GOLF CART...
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
