Used Kubota vs New LS
   / Used Kubota vs New LS #1
chsdiyer
Charleston
XG3025H
So in all my searching and considering my budget, the LS XG3025H seemed to be a no brainer. Today I found a 2013 Kubota L3200HSD with about 100 hours on it. Both packages would come with quick attach buckets, pallet forks, rotary cutter, and box blade. They are priced about the same though I think the LS will come in slightly cheaper. It seems the LS has a larger lift capacity which I still can't figure out. I hear people say, it's a 35hp tractor with a 25hp motor in it, but is the frame doing the lifting or the motor? Seems the Kubota should be able to lift more, but on paper it doesn't. The kubota certainly has more PTO power. Both are priced about 17,500, but the Kubota will take $500 to ship. If I went shuttle shift the LS would be about $1000 less, but not sure I'd like that transmission if this is my first tractor.
So a while back I posted a thread trying to understand why one would chose a used Kubota when they are more expensive than new other brands. And now I appear to be in that dilemma.
I really like the idea of buying new and the front loader capacity is certainly more appealing to me for LS, but nearest LS dealer is 2 hours away. Not sure how big an impact that is, i'd probably service it my self and most the guys in the LS forum haven't had the need for any warranty work.
Kubota certainly has a good reputation and that one is older but still practically new. Local Kubota dealer is about 10 miles away.
Anyone have any thoughts on this?
For me our needs are installing and maintaining a 500ft driveway, a workhorse for building our house...moving supplies around, removing some sapling areas 1-3" gum trees and wax myrtle, moving tree logs to mill,etc. Mostly front end loader work with some box blade for the driveway. Also will need the PTO to get the land graded (about 1.5 acres).
   / Used Kubota vs New LS #2
DOes the Kubota have any warranty left? I have the xg3025 and I love it. most chores require weight as well as PTO power. I just bush hogged a field that had 4-5 ft thick grass that has not been cut in a year and half. It chewed up everything just fine with a 6' bushhog. Broke 2 shear pins , replaced and kept going. Most implements operate at 750 RPM, This 3025 delivers that with ease. I have the shuttle shift and prefer it to Hydro due to power loss with the Hydro. What area are you using your tractor in? Have you thought of tires? With a new LS you can choose, The Kubota will cost to change. Good luck.
   / Used Kubota vs New LS #3
Have you, personally, physically inspected the used Kubota where it sits?
Has the Kubota been inside stored?
Are the rear tires loaded 3/4 with liquid?
Is the Kubota 4-WD? 2-WD was standard; 4-WD optional.
Maybe no sales tax on the Kubota. Probably sales tax on the new LS.
Are you going to pay cash whichever one you choose, or finance?
If financed the producer will include insurance. Kubota KTAC insurance is really good. LS may have KTAC's equal, I do not know.
As you forecast "mostly" FEL work I would prioritize that spec.
PTO horsepower is important if you will operate PTO powered implements. For grading, tractor weight and 4-WD are more important. Both tractors are 2,500 pounds, bare tractor. Both will be a little unstable lifting heavy FEL loads. Neither have a very wide wheel stance. The LS may be a tad wider. Plan on ordering the LS with rear tires 3/4 liquid filled.
I like having my Kubota dealer six miles away. Others do their own service and repairs. I am too old.
You will be good with either machine. Be safe as you learn operations.
TractorData.com Kubota L32�� tractor information
XG3�25H-24.4HP | LS Tractor
Hey Opie - I'm in coastal South Carolina so it's all sand. I dug down one day and got 10 feet in and nothing but sand. I've tried to watch some videos on shuttle shift and I just don't get it. It looked like the guy used the clutch to shift each gear to 4th. Then he stopped and pushed the clutch in, but only shifted the direction lever to go in reverse. So the other lever was still in 4th gear position. Is it not like a car where you have to shift back to first gear every time you stop?
As for the Kubota...I'm not sure if i'd like the rocker foot peddle.
Jeff - I have not inpsected either machine. Closest LS dealer is 2 hours away. I was going to go Saturday, but that one doesn't carry the hydro. The one I got the quote from is in NC and is about 4 hours away and not open on Saturday. The Kubota is 300 miles away in Georgia. The LS will just cost $120 or so to deliver, the Kubota is $500.
So neither will come with tax.
This is the Kubota which seems to be a great deal considering the dealer in town has the same year and he's asking 16,900 for just the tractor with more hours.
TractorHouse.com | 213 KUBOTA L32HST For Sale
Both are 4WD
Not sure if the Kubota is fluid filled tires, and LS wasn't quoted with it. Why would you only want to fill 3/4? Will it not "slosh" around in there if not all filled?
Will pay cash, and really wanted to stay at the 16k mark, but I'm going to need all those implements so I figured I better buy them now packaged and save a little long term. I think the Kubota warranty is up, if not 2018, the LS will carry 6 year warranty but no nearby dealers.
Another big one is my insurance company told me they would cover 100% replacement cost on the tractor if it's stolen up to 5 years old. Then it's prorated.
   / Used Kubota vs New LS #5
The only suspension in tractors is air in tires; no shocks, no springs.
If you fill tires 100% with liquid, rather than 75%, you l have no suspension. Also, 100% fill reduces tire squat and flex, both important to tire traction on dirt.
Filled tires have a distinct "feel" when traveling on paved roads in HST/High. Braking takes a tad longer.
Three quarters filled rear tires lower CG of tractor more than 100% filled tires. With loader work being your main task, and both your (current) tractors are heavy/light tractors, you need 3/4 filled rear tires and rear counterbalance when lifting with the FEL.
The WWII Ford 9Ns with steel wheels, no rubber tires, just steel paddles, were a terrible ride and on hard ground had zilch traction except in soft soil. Very low practical top speed and could not travel on paved roads. Restricting rubber supplied to Ford's tractors during WWII probably cost way more in diminished efficiency in the fields than the relatively small amount of rubber the tractors needed. (Gov't also restricted copper, so Ford had to delete battery starter and install a hand crank for duration of the war.)
Interesting. Thanks for the info and history lesson!
   / Used Kubota vs New LS #7
That Kubota is basically new, I would go with it since the prices are nearly the same. I like LS but the a Kubota is rock solid.
   / Used Kubota vs New LS #8
I usually set the gear and range for the task and go to work. If you ever get to the Myrtle Beach area you area more than welcome to come play on mine for awhile, You are correct i that the clutch is not like a car. 217 LS 325 w/loader 4x4 - farm & garden - by owner - sale
   / Used Kubota vs New LS #9
Both are 4WD
I love the rocker pedal.
Fill the tires yourself, it's easy. Fill to top of rim with valve stem up.
Is the price on the Kubota the asking price or have you negotiated already? How much below new price is it? Consider driving there with checkbook in hand and offer $1,000 less than they're asking. Be skeptical about a tractor that old with those low hours though.
Kevin
I was a little skeptical wondering why someone would trade in a complete package like that. The place it's at is very heavy equipment sales...no smaller stuff like tractors, so a little out of place. Apparently it's that guys personal tractor. There's a new looking B series in town someone has been trying to sell for a long time. He bought it for a house build that never happened so he ended up using it only a little to clear some stumps. It's not a 2013, but I guess some people get tractors and never end up using them. Maybe hold on to them thinking one day they will but then finally decide to let go. That's the asking price, and I hate negotiating. It seemed like a good price already to me.
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
