USED KUBOTA M4900
   / USED KUBOTA M4900 #1
rjohnson82
Niles, MI
Kubota M4900SU FEL --- Ferris IS2000 27hp Kaw 61"
Hey guys,
I'm looking at a used kubota that a guy is trying to sell because he has to move quickly out of state. It is a early 2000's Kubota M4900, FEL, 2wd, geared transmission. it has 691 hours and is in decent shape for its age and use. It has one leaky hose on the loader but other than that, it ran and operated perfectly. I have him down to $8500 and he's throwing in a used brush hog, box blade and landscape rake....Does this sound like a decent deal? I'm not up on used tractor pricing so any help would be appreciated. I know a new one of this caliber is $30k.
   / USED KUBOTA M4900 #2
Don't sound like a bad price but the reason it is so cheap is 2wd tractors with loaders don't sell. If its as clean as it looks and it fits your needs go for it.
   / USED KUBOTA M4900 #3
looks like a good rig. w/2wd and turf tires, (as mentioned above) your fel use will be somewhat limited. are the rears tires loaded? that would make a difference, would recommend if you buy good luck
   / USED KUBOTA M4900 #4
Your stealing it and you know it. Even though it's 2WD one w/ good tires around here would go for 12K plus W/O implements.
   / USED KUBOTA M4900 #5
Check if 2wd tractor REALLY fits your needs. All the rest is excellent for the price you have mentioned. Including if even you'll need to change tires (rims) into ag or industrial ones.
   / USED KUBOTA M4900 #6
If it meets your needs the way it's set up, then it's a good deal. Kind of unusual to see turf tires + loader on that size tractor. What will you be using it for? Does it have sufficient ground clearance for your intended tasks?
   / USED KUBOTA M4900
BOUGHT IT! Turns out it came with a basically brand new king kutter 6' cutter, box blade and landscape rake. I'm looking forwards to performing all the maintenance on it over the next few weeks :) any suggestion?
   / USED KUBOTA M4900 #8
That's is excellent price for the rig of that quality. You just can't top it better:thumbsup:
JC,
2018 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
12.7 LITER DETROIT GENERATOR SKID (A50854)
12.7 LITER DETROIT...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
