timcboyle
It's time to replace the tires on my Kubota L3130.
I'm not sure which way to go on tire sizing, could use some advice.
The tractor was purchased used four years ago and came with the following size tires (now worn out):
Front: 10-16.5
Rear: 16.9-24
These seem quite wide to me, and the rims of course are suitably wide for these tires. But the specification size tires for the 3130 are:
Front: 7.2-16 (4WD)
Rear: 12.4-24
Are there advantages or disadvantages to having wider-than-spec'd tires on a 3130? The usage here is agricultural and pretty light -- hauling moderate weights with trailer, bush hogging, muddy conditions at times (Fiji), light tilling.
I am wondering whether to simply replace these tires as is, or convert rims and tires to the spec'd size.
I thought about maybe getting rims and tires to match those on our two L4630s so we can standardize on one size (helpful when you need a spare). The spec'd tires for the L4630 are (and this is what we have) and maybe I could get away with these on the 3130, they're a bit wider than spec but not as wide as what I've been running with:
Front: 8.3-16
Rear: 14.9-24
What would you do if you were me? Thanks in advance!
-Tim in Fiji
Front: 10-16.5
Rear: 16.9-24
Front: 7.2-16 (4WD)
Rear: 12.4-24
Front: 8.3-16
Rear: 14.9-24
-Tim in Fiji
