Used hydralic fluid and diesel for trailer deck?
   / Used hydralic fluid and diesel for trailer deck? #1
paulsharvey
Elite Member
Hawthorne, Fl
Kioti CK2610 HST
I know there have been 500 threads about treating trailer decks already. Most seem to be about useful motor oil; either straight or cut with kerosene, ATF, or diesel. I've got about 5 gal of hydralic fluid sitting in a drain pan, and was just thinking about rolling it on trailer deck, maybe with about a gal of diesel to thin it out. My only concern is would hydralic stay slick on the wood deck?
Really the best wood treatment I've ever really seen is the diesel bucket on a paver you clean shovels in. The broken down AC and diesel do a great job on shovel handles.
   / Used hydralic fluid and diesel for trailer deck? #2
Just a guess but most any petroleum product will make a wood deck slicker. I've applied linseed oil on my trailer deck. Get it boiling hot - apply with a roller. It really soaked in. But it did make the deck slicker.
   / Used hydralic fluid and diesel for trailer deck? #3
Use boiled linseed oil. You can cut it with mineral spirits or citrus oil. Boiled linseed oil will be tacky for a month but eventually it will cure to a hardened surface. Sun helps, and there are other tricks to make boiled linseed oil cure faster. That is the most common cheap finish on old wood decks. If you buy the boiled kind of linseed oil you can put it on at any temperature. Do not buy unboiled type, boiling is a controlled process.
That is much better than motor oil or hydrauic oil which stays messy forever and never cures.
As for what to do with the old oil, I've heard that places that sell it are required to dispose of the used oil.
Around here, some do and some don't.
rScotty
   / Used hydralic fluid and diesel for trailer deck? #4
if using linseed take extra precaution to handle used oil soaked rags, rollers, etc properly. they go through a post use heating & can spontaneously catch fire in certain conditions. happened to me once, glad i caught the smoldering rags in time in the garage.
also as a footnote (others may have different results). being organic base, i've had wood products such as screen doors, etc, turn black in 6 months from i guess fungal or bacterial growth. may not make a diff in your application, regards
   / Used hydralic fluid and diesel for trailer deck? #5
Linseed oil is a prety crappy exterior wood Preservative. It allows mold and fungus to grow. If those can grow you know water is soaking into the wood.
   / Used hydralic fluid and diesel for trailer deck? #6
that's why i stopped using for exterior use. even interior, it will darken over the years
   / Used hydralic fluid and diesel for trailer deck? #7
I dump all of my used oil, engine, hydro, whatever, into the same jugs. I use the oil straight without mixing with anything on my trailer, snow fences, and anything else made of wood that won't be coming in the house. I coat the trailer every year. It is slick until dry. It will be slick when it rains. But it is not slick enough when dry to cause any issue and it generally does not come off on anything. I usually do it when I know there will be 2 or 3 nice, warm, sunny days to let it set.
   / Used hydralic fluid and diesel for trailer deck? #8
I use motor oil or used hydraulic fluid whatever I have an abundance of at the time but I try to cut it with an equal amount of diesel fuel. I try to apply it on a good hot day ( which where you and I are there is no shortage ) I use a paint roller on a stick with a roller screen in a 5 gallon bucket and it soaks in just fine, a mop will work to and a lot faster but IMO you waste an awful lot and definitely not as environmentally friendly.
   / Used hydralic fluid and diesel for trailer deck? #9
Use it, It doesn't make it slicker after it dries, it dry.
The trailer is only like 3 or 4 (maybe 5 at this point) years old, and between sun and rain, the 'non ground contact' pressure treated wood is looking worse for the wear. I'm not trying to get 50 years from the deck, but don't want to replace deck every 8 years either...
So, yeah, I figure I'll cut with diesel and roll.
VOLVO 12.1 L FRONT CLIP (INOPERABLE) (A45046)
VOLVO 12.1 L FRONT...
Ryobi Compound Miter Saw (A44391)
Ryobi Compound...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A43003)
1993 INTERNATIONAL...
2009 Saturn Vue SUV (A42744)
2009 Saturn Vue...
2006 INTERNATIONAL 9200i SLEEPER (A43004)
2006 INTERNATIONAL...
New/Unused Greatbear 78in Grapple Bucket (A44391)
New/Unused...
