Used Equipment
   / Used Equipment #1
Ozarker
Veteran Member
Yanmar 1500D
I noticed that much of the conversation on implements is about new stuff, brand, etc. So how many go to auctions or just go looking for used equipment?
Lets hear about the good, bad and the ugly on buying used stuff. For example. if I look for a used finish mower, what should I look for? What should I avoid? What is a warning sign that I should walk away? Not just brand stuff but do's and don't across the brands.
How about it? Been stung lately? /w3tcompact/icons/laugh.gif
   / Used Equipment #2
I'd have no problem buying used equipment (cars, trucks, tractor or implements). In fact, my 670 was used. I've got two used implements now:
A) Befco finshing mower (purchased when I got the tractor) which has been real nice. I've got to replace the belt (Thursday's task), but it does a fine job cutting.
B) 6' Back blade which is ancient (40+ years, I'll wager). Other then an overall look over and make sure everything moves or rotates, not much can go wrong with a back blade.
I've been looking for a cutter (only saw a few 48" units so far)...this is what I've been doing:
For the mower or rotary cutter, gear box is lubed and turns freely and the blade(s) rotate when the gearbox turns. If possible, try to shake the blades to check for worn bearings...look at the blades while you're at it. If the owner doesn't mind, pull the belt cover(s) off and examine the belt for tension and wear. Wear wouldn't be a show stopper, but since a belt will cost $30-$50 ($38 for the Befco) you might get a little more off the price. Visually examine the grease fittings. If dry, the unit may not have been maintained well. Also, check out the caster wheels for free movement.
Obviously, this assumes the mower/cutter is not hooked up to the tractor!! I'm also assuming the PTO shaft is attached to the implement. Speaking of the PTO shaft, make sure the release mechanisms aren't rusted and are functional. Slowly rotate the PTO shaft until you feel the resistance of the gearbox, then reverse rotate....that should give you some idea of the wear in the U-joints.
If the mower/cutter is rigged to a tractor, ask if you can see (and hear) the implement in action.
I'll tell ya one thing that always impresses me...if the seller offers up the Operators Manual when you're looking at the unit.
   / Used Equipment #3
I wouldn't worry about a used box blade or carry all so much as a mower. The reason is simple for me. I don't have to worry about a gearbox, etc., on the box blade or carry all. I think I'm less likely to get stung on something like that. Not immune from it, mind you... just less likely is all. /w3tcompact/icons/smile.gif
   / Used Equipment #4
The first thing I look for on equipment is the bushings. Especially on stuff that has hydraulic cylinders and moving parts. Look for wear and sloppy fit. That'll tell you if it's been rode hard for a long time.
Another thing is to inspect the rods that are exposed on cylinders. If you look careful you'll see if it has grooves or a bow.
Another thing I always look for is signs of using the wrong tools to repair something. Stuff like rounded bolts and nuts etc. Chances are if they didn't use the right tools they didn't do the repair right either.
But mostly I look for tightness and general condition.
   / Used Equipment #5
I was typing while Roy was. I have to say if I knew all he did about them, I wouldn't be concerned about a used mower either. /w3tcompact/icons/smile.gif
   / Used Equipment
<font color=blue>I'll tell ya one thing that always impresses me...if the seller offers up the Operators Manual when you're looking at the unit. </font color=blue>
I knew there was a reason I keep all those in the file cabinet.
   / Used Equipment #7
"I have to say if I knew all he did about them,"
Thanks, but most of this is common sense with a little mechanical knowledge...very little.
Any machined compnents should have little slop and should function smoothly. If a shaft rotates, there should be minmal play in any direction other then the rotational direction. If the end of a blade moves up and down, it indicates wear in the bearings. One way to get a "feel" for this is to look at a new unit (at tractor Supply, for example). Then using a little sense, one can make reasonable judgements. First time is tough..after that, no sweat.
   / Used Equipment #8
I'm a big believer in buying used equipment. Both my tractors are used (vintage actually!), and many of my implements, such as a manure spreader, hay baler, kicker wagons, two bottom plow and three point hitch snow blower.
The info that the guys provided earlier is excellent. If possible, try out the equipment before buying (of course it's not always possible). If you're careful, you can really save a lot of $$$$!!
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2020 PETERBILT 567 DAY CAB (A53426)
2020 PETERBILT 567...
2016 Ranger 570 EFI (A52384)
2016 Ranger 570...
2013 Dragon Double Rail Roll Off Trailer (A53117)
2013 Dragon Double...
