Used Bush Hog Value
   / Used Bush Hog Value #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
Found this on Craigslist the other day...
Thought that it might be worth a look since it is local...
Appears to be in decent condition...
Any thoughts would be appreciated...
Allied Bush Hog
   / Used Bush Hog Value #2
Looks like a few holes in the deck - are you handy to weld them up? Also looks 30+ years old, so I'd want some assurance I could get parts (blades, special bolts, height adjuster, etc.) for it.
I'd say it's worth a look, but squint a little...
Jim
Jim
I can weld it up with no issue...
If gearbox is good might be worth an offer of $800...
   / Used Bush Hog Value #4
Check the gearbox for oil. Some pump grease into the box when the bottom seal fails due to age, wear, etc. It's a hidden defect.
Safety issue ... the PTO guards are missing. After shutdown, the shaft will be spinning just from inertia. :eek: Beware of getting caught.
   / Used Bush Hog Value #5
Allied Bush Hog
Its a pull type mower which you know but will your tractor handle a 7 ft mower I know new these go for big bucks but it's not new 800 would be on high side for this mower IMHO.
   / Used Bush Hog Value #6
Rocky's right 8hundreds too much. It's old - $400 sounds much better.
   / Used Bush Hog Value #7
It's a Bush Hog 307 pull type. IF the gearbox is sound and IF you are in the market for a pull-type cutter, $900 is not too much, but there always has to be some dickering. You gonna run that with the 1720?:D:D
Pull types are nowhere near as manuverable as mounted R/C's. And PM me with the gearbox tag number or a gearbox housing casting #. There may be an obsolescence problem with early 307 gearbox parts.
Looks like we are coming down for Thanksgiving-- I'll be in touch.
   / Used Bush Hog Value #9
It looks good, but I do notice that it may be slinging out some gear oil from the seal on the input shaft. If you go look at it, check that very close, and ask questions!
   / Used Bush Hog Value #10
whats with the barbed wire wrapped all up in the shaft?
That may be telling if there too lazy to unwind or cut the wire off the shaft what else has been overlooked?
HONDA EB 3000C CONVERTER (A45333)
HONDA EB 3000C...
2014 LOAD TRAIL GOOSENECK TRAILER (A45046)
2014 LOAD TRAIL...
Husqvarna 120 Chain Saw (A44391)
Husqvarna 120...
Kubota M6-141 (A44501)
2007 (INOPERABLE) INTERNATIONAL DF567 (A45333)
2007 (INOPERABLE)...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
