Mowing Use rotary mower without tailwheel?
   / Use rotary mower without tailwheel? #1
anojones
WA
JD 3320
I have a light duty Deere LX5 rotary mower and I've bent the tail wheel and the bracket holding the tail wheel so now it won't rotate and just digs into the ground. I've taken off the tail wheel assembly and don't have the heat or a big enough hammer to get it back into shape. Can I just mow without the tail wheel? Any downside or damage I'm gonna do? I'm not even sure what the wheel is doing for me when it's working right.
   / Use rotary mower without tailwheel? #2
Probably won't hurt the hydraulic lift to run the mower without a tailwheel, but I wouldn't do it. Unless you have extra weight on the frontend that's gonna make the front end lighter all the time, which could make the steering a bit tricky. One purpose of the tail wheel is to help give a consistent cutting height.
   / Use rotary mower without tailwheel? #3
I deally the tailwheel carries part of the mower weight, and the 3pt adjusts front height.. you loose alot of 'adjustment' control from your right hand by not using the tail wheel.
got a plumbers torch? you'd be surprised what patience and blue flame can do.. that and a pipe wrench ont he end of a 4' pipe.. lotsa leverage..
soundguy
   / Use rotary mower without tailwheel? #4
I suspect this is another of those situations in which "Yep, you can do it, but you ain't gonna like it.":D
I'll try the propane and see if I can bend it back, if that doesn't work I'll buy a small MAPP torch.
   / Use rotary mower without tailwheel? #7
I have done the same thing to my MX-6 twice. I will not use it without a tail wheel and it took a lot of heat to get it back working the first time.
   / Use rotary mower without tailwheel? #8
I would either get a torch and heat it, or take it to the local welding shop.
It was designed for the tailwheel so it needs to be there. As Soundguy pointed out you could lose a lot of adjustment to. I also think you would be stressing your lift arms to a degree. Just my take on it. :D
   / Use rotary mower without tailwheel? #9
have some patience.. metal heats up pretty slow the larger it is.. but it holds heat real good.. let it 'soak' for a good 5-10 minutes.. then start bending on it..
soundguy
   / Use rotary mower without tailwheel? #10
I've bent the wheels on the finish mower a couple times. A BFH sledge can do a pretty good job on them but I've broken at least one doing that and had to buy a new U bracket for the wheel. But it is doable.
Steve
2 Row Custom Produce Cultivator (A52128)
2 Row Custom...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
Navigator 4000 4,000lbs Forklift (TRUCK MOUNT) (A52128)
Navigator 4000...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
