Loader Use of bucket hydaulics for snowplow / L2900 help
   / Use of bucket hydaulics for snowplow / L2900 help #1
jodije
kubota L2900
I have a L2900 that I mounted a snow plow to the loader arms which provides the up and down motion and that works great.My problem is when I connected the plow turn rams to the bucket hydraulics it only works in one direction.There seems to be back presure that blocks movement the other direction.When I reverse hoses it does the same thing but in the other direction.Does anyone know a reason why the hydraulics for the bucket will not work on a snowplow.I'm stumped and need help. John
   / Use of bucket hydaulics for snowplow / L2900 help #2
Re you sure you are pushing the lever hard enough to get past the float detent? It seems obvious, but I did not figure it out on mine until someone told me just to push the lever harder.
   / Use of bucket hydaulics for snowplow / L2900 help #3
I had the same problem. even the dealers parts guy said it wouldnt work and I didnt listen. I played for days with it and nothing come to find out it has a ''re-gen'' system.
Somehting about it sending oil through the cylinder both ends. I know there are threads on here about it...
It alows the bucket to dump faster and also no lag time with it.
ill look for info for you...
But It wont work if it is this type of set up. sadly....
http://www.hwhcorp.com/ml37939.pdf
Hope this helps. I forget who but there was one member here who explained it VERY well for me a wile back...
http://www.tractorbynet.com/forums/john-deere-owning-operating/54360-what-do-you-use-regen.html
Here is the older post that explains it good.
http://www.tractorbynet.com/forums/kubota-buying-pricing/9403-3-position-valve-vs-4-a.html
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
Unused Delta Crash...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
