Use a tractor to launch a boat?
   / Use a tractor to launch a boat? #1
BluRidgDav
I'm thinking about buying a big trailerable fishing boat (5000+lbs). I'm also planning to get a tractor for mowing, light FEL, etc. Anybody use their JD to pull a boat? I don't mean just move it around the driveway. But rather to tow it about a mile down a rural road and launch & retrieve it from a public boat ramp. Could a tractor light enough to be used as a lawn-mower (2210 - 4210) be strong/heavy enough to pull a big boat out of the water?
   / Use a tractor to launch a boat? #2
Short answer: Yes
Long answer: You bet your bippy.
A 4 wheel drive tractor could pull the boat and the tow vehicle up the ramp.
   / Use a tractor to launch a boat? #3
One of the main concerns is having enough braking to stop tractor, trailer and boat on a steep ramp. I have seen a couple of trucks and motor homes end up in the water because there was not enough brakes on tow vehicle to stop on a ramp. Sa
   / Use a tractor to launch a boat? #4
I agree with Ron and Mike that a trailer will definetly tow a 5000# boat on a trailer. I move my 4000# boat and a 30' 5800# camper trailer around with my 2615HST. However, my towing is on mostly flat ground around the yard. I would not attempt to tow 5K up or down any grade such as a boat launch. Most tractors (don't ask me how I know) don't have the stopping power to hold them on such a grade.
   / Use a tractor to launch a boat? #5
My 2210 gets squirrely towing a 3,000lb. boat + trailer on inclines if I don't have the loader on. I wouldn't want to launch on a steep ramp with it.
   / Use a tractor to launch a boat? #6
I pull my 21' CC around with my 3320. However I do load the bucket halfway with dirt to counter balance. Works fine and I feel safe doing it this way.
Bob
   / Use a tractor to launch a boat? #7
braking is, or can be, a definite issue. If that HST control goes into neutral for any reason, you may not be able to stop it. Power to pull, assuming good balance, should not be an concern.
   / Use a tractor to launch a boat? #8
Towing it a mile or two is not the issue. It is the steepness of the ramp as others have said in light of the tractor weight. I tow my 22' ft dual hull boat with a JD790 -- no problem.
Weight of the tractor on a muddy bank, for example, may be a concern.
Also, when maneuvering my 8.5 ft wide boat into my barn for the winter, I far prefer using my tractor. Much, much easier.
Finally, don't forget that with the up/down leverage with the 3PH, it is much easier to raise or lower the boat in comparison with a truck.
   / Use a tractor to launch a boat? #9
I have had a problem launching behind my 4300 in shallow water. The boat was not all the way on the trailer with negative tongue weight. The 3ph lifted up which then made it even harder to pull the boat on. The shore was too muddy to back out to deeper water. I have also used the reciever on the back hoe to launch/recover. It works like a dream for backing trailers into tight spots, just swing the boom to steer the trailer, lift to dump /forums/images/graemlins/smile.gif.....Pat
2001 Dodge Ram 2500 Pickup Truck Extended Cab (A44789)
2001 Dodge Ram...
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
2014 Ford F-250 XLT 4WD - 6.2L Gas - Ready to Go to Work (A44789)
2014 Ford F-250...
Chery 14' Bi-Parting Iron Gate (A44502)
Chery 14'...
2013 JLG  10054 SKYTRAK(INOPERABLE) (A45046)
2013 JLG 10054...
NEW 2017 Xtreme Green Utility Vehicle 72V w/Locking Tool Drawers, Tow Hitch, LED Work Station (A44789)
NEW 2017 Xtreme...
