thatguy
Elite Member
OK.. I did something stupid, I tried to flush a disposable (but NON flushable) toilet cleaning wand "end".. TWICE !! Yes.. in two separate toilets.. Now both toilets are stopped up, not completely, but they dont flush correctly... It seems that this "end" is lodged in the toilets since it will flush, but take a couple times..
This "end" is got a nylonish scrub brush mounted to a hard plastic backing.. That then mounts to a handle that you retain for future use..
At first I thought i would use a plunger to force it on down the system, but then I thought I needed to get it out of the system.
So I decided to take the toilet up and just get it out..
I turned the water off and drained the tank and bowl.. But when I started to take the bolts off the plumber mounted the toilet then hacksawed the bolts shorter.. And guess what - you cant get the nuts off the bolt..
One of the bolts is now turning as well...
Any suggestions?
Brian
Any suggestions?
Brian
