Urethane edges?
   / Urethane edges? #1
dylan
ottawa, canada
Toolcat B series
Just wondering if anyone has ever tried Urethane edges on their buckets? (tractors, skidsteers) I was thinking that it might prevent some scrape marks during winter snow removal and especially when scraping material off the road or driveway during summer construction. I was also wondering how these edges might affect the digging action of the bucket. Any thoughts or experience with this situation?
   / Urethane edges? #2
I've been asking the same question in the "snowplow and rear weight" thread. This is part of a response I got from a metal cutting edge user:
<font color="blue"> I have been plowing the drive for 20 years now with a 8 1/2' Fischer snow plow mounted on a 79 Ford 250 4wd.... I have used the blade for so long without the shoes, that I don't even know where they are now....I have neighbors that used the plastic blade edge and they wear them out every 2 or 3 years and they are expensive to replace. My cutting edge has been flipped once and is due for replacing now. $100 for a new 8 1/2' metal edge or $250 for a 6' plastic..... this is what I call a no brainer....
To finish up what the truck leaves behind, I do some clean up work with a old Bolens with a 54" blade with a metal edge. </font>
Another writes: <font color="blue"> As for the blade, mine came with the normal steel edge and the steel shoes, and that's what I've always used. </font>
I appreciate the above input, but hearing from urethane edge users would be good to help us newbies make up our minds.
OkieG
   / Urethane edges? #3
I wrote the part about the 79 Ford.........
Now for my comments on the plastic urethane edge for a loader bucket ..... first, it would be mounted with the thin side parallel to the bucket bottom and it would wear very rapidly since it is only about an inch thick and the height part would be horizontal instead of vertical the way that it was intended to be used. Another problem that you will incur is in how to mount it. If you used standard moldboard mounting bolts, they would still scratch on the driveway surface and you would still have the resulting line marks from them. Also the heads would soon wear off and there would be very little holding the blade edge onto the bucket. I understand your reason for wanting to try this product, but I don't think that you can successfully engineer it to work in a design that it wasn't originally designed for given the reasons that I have provided. If it can be done, I will be the first to applaud you for your success.
   / Urethane edges? #4
Junkman,
Thanks for the post. Dylan was asking about buckets (which you responded to) and not blades (which I addressed). I read what he was asking, then shifted gears in my response.
Sorry Dylan, I didn't mean to throw your line of questioning off track. I just picked up on the urethane vs. steel issue and steered my post to blades.
OkieG
   / Urethane edges? #5
Use a piece of horse stall mat. You can buy a 4'x6' mat at TSC or Southern States for less than $40. I cut it into 8" strips and bolted them on to the rear blade edge and replaced my toothbar with them. They lasted all winter and I have extras for this year. Works real well - it's like using a squeegee on your pavement.
Do a site search on "horsemat" or "stall mat" or other varations, and you will find several pictures of this application. Hey, you didn't think it was MY original idea, did you /forums/images/graemlins/crazy.gif?
Mark
   / Urethane edges?
Thanks for the replies guys. I will look for the mat.
I had planned on counter sinking carriage bolts so they wouldn't scrape the pavement and using the loader tilted downward so only the actual edge is wearing. Not the whole flat bottom. Just have to try it I guess.
   / Urethane edges? #7
Around here in Northern Michigan we use a 3" dia. pipe slotted down the middle to fit over the cutting edge. I've used one on my 7 1/2' plow on my pick up for the last 20 years. I've also made a few for tractor buckets and rear 3 pt. blades. The pipe floats over the ground, grass, and concrete and keeps it from diging in. Best of all there's no torn up grass in the spring. /forums/images/graemlins/smile.gif
   / Urethane edges? #8
Hi Dean,
Welcome to TBN. That slotted pipe idea sounds like a good one. How do you slot the pipe?
OkieG
   / Urethane edges? #9
"How do you slot the pipe?"
I have not done it, but if you have a tablesaw, you can screw a length of 1x2" or 3" board to the pipe to keep it from turning, Raise the blade just enough to cut through one side and keep from hitting the screws and run it through, using the fence, just like ripping a board.
   / Urethane edges? #10
Hi Norm,
What kind of pipe are we talking about? I guess I assumed Dean was talking steel pipe. And, I think you are talking about PVC?? /forums/images/graemlins/confused.gif Maybe either would work??
OkieG
UNUSED FUTURE XKH39 39" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE...
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
202479 (A54757)
202479 (A54757)
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2010 Specialized Structure 1456 Tri-Axle Portable Office Trailer (A55852)
2010 Specialized...
2018 Deere 323E (A53317)
2018 Deere 323E...
