Upgrading Mobile Home Axles??????
   / Upgrading Mobile Home Axles?????? #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
A little background:
Our trailer is a 18' and has two mobile home axles under it. One is a brake axle that doesn't work. It is a heavy built trailer that was homemade in 1984.
It is a seldom used trailer. Maybe 8-10 times per year @ less than 10miles each way, and maybe one longer trip per year @ ~50mi one way.
The tires are getting pretty bad. Dry-rotting, leaking, bald, etc. We have put tubes in a couple due to the leaks.
The main thing that gets towed is my tractor @ 4500lbs MAX, sometimes less depending on loader/attachment configuration.
So we are weighing out our options on wether to buy tires and maybe fix the brakes on the brake axle, or to just buy new axles and tires. So I would like to here all the suggestions TBN members have. Here is what I have come up with so far:
New brake axles are $235 locally and $135 for non-brake axles.
New rims+tires are $75 each
New rim and used tire are $25 each.
So two new axles (1each) with new tires/rims would run me $670, or $470 with the used tires.
Some concerns are, I have heard that MH axles are 4500lb rated. Which I like better than 3500lb. But, is there any bolt on conversions that would work to convert to newer style wheel/tires. I am not really worried about the brakes, they haven worked since I owned the trailer, but I may fix anyway.
Sorry for the long winded post, but basically this trailer cost me $400 5 years ago and I havent had to do anything to it yet. I really dont want to sink anymore money into it than I have too given that we don't use it much. So is it worth it to buy new axles??? or just get new tires and fix the brakes???or are there any other options I have not came up with??????
   / Upgrading Mobile Home Axles?????? #2
I know you are not concerned with brakes but the law states in Ohio any trailer over 2,000# must have brakes, does not say how many axles, and they must have a brake-away kit that will hold the brake for 15 minutes.
If it were my trailer I would put a set of 5,200# axles on it with 6 lug wheels and 225/75/15 tires.
State Towing Laws
Chris
   / Upgrading Mobile Home Axles?????? #3
I agree.. even if I just put dexter axles with one of them as a brake axle.. I'd do it.
and tires? NEW.. used ones are already half way to letting you down.
I've had 3 bad tire issues in the last 2 months.. could have been bad situations when they decided to let go..
soundguy
   / Upgrading Mobile Home Axles?????? #4
Here is some more info on the trailer laws in Ohio. I got it from one of my online sources I get from being in the marine business.
Ohio Bureau of Motor Vehicles - Trailers: 614-752-7568
Maximum Speed Limit: 65
Maximum Dimensions for trailer:40'L x 8'6"W x 13'6"H
Maximum Length with Trailer:65'
Minimum Weight requiring Separate Trailer Brakes:2000
Safety Chains:Y
Brakelights:Y
Taillights:Y
Clearance Lights:Y
License Light:Y
Turn Signals:Y
Reflectors:Y
Flares:N/A
Breakaway Brakes:Y
Tiedowns:N/A
Two Trailers:Y
Insurance:N/A
Wide Trailer Permit Phone Number: 440-351-2300 Tpke: 440-234-2081
Chris
Yes I am aware of the laws and yes only one axle needs brakes which it has.
They just need rebuilt as they dont work properly.
IF I were to get new axles, one WOULD have brakes.
IF I keep these axles, the brakes will eventually get rebuild.
What I ment about not being worried about the brakes is IF I can find a kit to convert the hub, I would leave the MH style brakes. IE I am not worried about converting them.
5200lbs is overkill and is more than I am going to want to soend unless they are cheaper than 3500lb axles which I doubt. I only own a 1/2 on and a little tractor. If I ever have a need for bigger, I will cross that bridge when the time comes. For now, I want to do this as cost effectively as I can.
I have red on a couple of websites that MH axles have a 1 3/4 inner bearing diameter and an 1 1/4 outer which is common on a lot of 6 and 8 lug hubs that go on 6k axles and that some of these hubs will work. I was wondering if anyone can confirm or deny this??? Has anyone on here ever done this before?? I will have to reasure the distance between axles to see if I could even accomodate larger tires, but around here, junkyard 8 lug 3/4ton axles and tires are cheap.
   / Upgrading Mobile Home Axles?????? #6
You're most of the cost of a factory built used trailer at that amount. I don't disagree with the others that the new stuff is better than the used stuff, but you have to be careful throwing good money after bad.
Every region is different, but around here I can find a good used 2-horse trailer any week of the year for about $500. Some show up for less if they're rusty or dented up. You might look around for a used trailer of some sort that you could poach the axles off of.
I have a trailer with mobile home axles that were adapted to fit conventional rims. The tabs were ground off the hub and an adapter plate was mounted that fit regular rims.
If your current setup has been working for you, I'd say fix the brakes and replace the tires. The magnets for those mobile home axles can be found on e-bay. I think R&P sells them sometimes. They're around $50 if I remember correctly.
   / Upgrading Mobile Home Axles?????? #7
I have not seen mobile home axles rated for less than 6,000 pounds.
We have a similar vintage trailer that refurbished last year. I replaced the mobile home axles with newer mobile home axles with brakes on both axles. The mobile home axles cost $75 each including brakes. I can buy all the used tires I want for $25 each including the wheeld.
The mobile home axles needed to be cut in the middle and welded to be the correct length. Replacing the axle was cheaper and easier than rebuilding the brakes.
Where are you buying axles and tires at.
Around here, people are selling MH axles with marginal tires for $100 a pop with no guarentee that the brakes even work.
No more than we tow, I cannot justify buying new tires. They dry-rot before even half the tread is worn. A used but not dry-rotted set is the way I think I am going to try to go.
Used trailers around here also bring a premimum. $1500 for factory build car trailers is about the norm. People are selling homemade peices of junk with rotten decks for ~$800.
   / Upgrading Mobile Home Axles?????? #9
We have a 2 horse trailer with tandem axles for sale at the end of my road for $500. Have not looked at it but there has to be $500 worth of steel, axles, wheels, tires, brakes, ect there.
Chris
   / Upgrading Mobile Home Axles?????? #10
I buy axles and tires from a mobile home dealer. They use them until they are worn out and then sell them to a refurbisher who I assume pays less than they charge me. I was able to look at their inventory and cherry pick the axles and tires I wanted. The axles and tires I purchased had plenty of life left in them. I did not test the brakes before buying but was able to see that plenty of pad remained and everything moved slowly. I did have to replace one of the brake magnets after the wires pulled out of it which cost about $25.
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2018 Allmand...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
Ford 641 Workmaster (A50514)
Ford 641...
1240 (A50490)
1240 (A50490)
