Update on mower bogging down
   / Update on mower bogging down #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Well, I think I found the culprit. As you might know I run custom blades. i had new ones made recently, and from a different source. I just realized that they look different. Couldn't figure out why. Turns out it is the angle of the cut of the blade. These guys did it at a 45 (1/2" steel) the previous and factory look to be 60 to 70 degree cuts. I am pretty sure this is what is causing the constant bogging of the mower.
I will get through this season, and deepening the pockets but order new blades this fall, including greater rake on the blade cut and hardened steel (the soft steel blades bend so easily).
   / Update on mower bogging down #2
Its amazing what the pitch of the prop can do to an airplane, so its pretty much the same thing on a mower blade. You face cutting resistance from both the grass and the wind. Good observation. :thumbsup:
   / Update on mower bogging down #5
Carl,
What was the original thickness of the metal in the blades, and the weight differences in the old and new custom blades?
I tried double blades one time in an X pattern., and it slowed the rpm a good bit. so I switched back to the standard blades.
I would say my RPM is down a bit, noticeable but not problematic.
Original blades are 3/8" I think (will measure) and I will also weigh.
I think my blades are more like 180 degree. :confused2:
Darn it. i just caught my typo. 45 degrees. Couldn't figure out what you guys were on about. So embarrassed. The angle of the current cut on my custom blades is 45 degrees and should be a lot shallower like 20 degrees.
   / Update on mower bogging down #9
Oh don't mind me, i was just being silly about how dull my brush cut blades are. I really need to get them off and clean up the edge a bit.
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
2014 Ford F450 Altec Bucket Truck (A52377)
2014 Ford F450...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
CHALLENGER MT525B TRACTOR (A51247)
CHALLENGER MT525B...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
