Update on Kohler command 23hp oil keak
   / Update on Kohler command 23hp oil keak #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I have been chasing an oil leak on my mower since I got it. Figured it is coming from the oil filter. I have been taught, and have replaced every oil filter in my life, by hand (at least tigtening). Well, I think my oil flange has a slight warp. It finally took me putting a wrench to the filter and it all tightened down.... No more leaks but getting it off will be a doozey.
   / Update on Kohler command 23hp oil keak #2
too bad hope it works out, are these engens known for this problem, was thinking of getting a cub cadet gt. with a with a 20 hp.
   / Update on Kohler command 23hp oil keak #3
I always follow the instructions on the filter -- they usually want 3/4 to 1 turn after contact. Normally that is more than I can do by hand.
I am more like 1.5 turns now. I have never had an issue with a 3/4 turn by hand but there is a new time for everyone. As for the Kohler, I think it is a well built engine. It is no Honda but even they have their issues....
   / Update on Kohler command 23hp oil keak #5
What type of oil filter are you using? When I run into that type of problem, I try to get an oil filter with a thicker gasket on it. Usually works for me.
Napa / wix... What brand would have a thicker gasket?
   / Update on Kohler command 23hp oil keak #7
try briggs.
   / Update on Kohler command 23hp oil keak #8
Double check that its your filter seal leaking rather than the drain plug. My drain plug kept wanting to shake loose and leak oil. I had to add loctite to the treads.
DMI D300 Gravity Wagon (A39855)
DMI D300 Gravity...
2017 INTERNATIONAL 4300 26FT BOX TRUCK (A43004)
2017 INTERNATIONAL...
1200 Gal Nurse Tank w/ Mixer (A40784)
1200 Gal Nurse...
Topcat Skid Steer Tree Shears (A42021)
Topcat Skid Steer...
2015 Kenworth T800 T/A Day Cab Wet Kit Truck Tractor (A42742)
2015 Kenworth T800...
2015 Chevrolet Impala LT Sedan (A42744)
2015 Chevrolet...
