unsynchronized tranny use?
   / unsynchronized tranny use? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander max 1000 6x6, Ego lawn mower
Seems John Deere put unsynchronized transmissions in many of its compact tractors built in the 90's and early 2000's. If you have one of these, how has loader work been for you? We are seeing 770's and 790 tractors come up FS.
   / unsynchronized tranny use? #2
I used to run an old IH 574 loader at the farm. It was all I knew, but now with a hydro, it was a horrible loader. We wore out the shift linkage several times while I was a kid. We did load thousands of loads of manure with it though. If I were ever going to do a significant amount of loader work I'd personally look for a hydro.
   / unsynchronized tranny use? #3
My 2005 5105 doesn't have a loader. The only synchro is between low and reverse ranges. You still have to clutch and shift to change direction. To make it worse, speeds in reverse range are higher than in low forward range. To back up at the same speed I have to shift the main transmission too. If I had to do loader work on it, or mowing that involves a lot of backing up like I have to do in California, I'd disllike the transmission even more.
   / unsynchronized tranny use? #4
Many of the shuttle transmissions have a faster reverse then forward, more power with throttle to dig into a pile or scoop up, then reverse and back out to dump and reduce the throttle to have the same travel speed.
   / unsynchronized tranny use? #6
The power reverser transmissions allow for clutch-less forward and reverse shifts at lower speeds for loader work.
Other than Kubota’s glide shift transmission most of the power reserver units are higher horsepower tractors although there may be ones I’m not familiar with.
   / unsynchronized tranny use? #7
My 1070 (pre-790) doesn't have synchronized gears. It's no big deal once you learn the throttle/rpm of the gear you are going to. Never had a problem with doing loader work. I taught a young woman how to run a baler from it (2 stage clutch). She had never operated a geared vehicle of any sort. Picked it up on the way to the fields.
   / unsynchronized tranny use? #8
Massey Ferguson has power shuttle transmission available in many of the 40+hp machines, and I think TYM has them starting in the 50 hps or so range.
I like HST, but also, a Well Done powershuttle really had about all the advantages of an HST too. I belive many (most?) PST can shift between gears in the Same range will moving, as well as forward to back; but I think you need to come to a stop to change ranges? My PST experience is on front end loaders, reach forklifts, back hoes, and in those applications, it's fantastic, but those all had a single range, 3 or 5 speed, that could be shifted on the fly.
   / unsynchronized tranny use? #9
I'm thinking maybe I should look newer and look for a HST.
I think you should too. I know someone with a late 80’s JD with a manual transmission and he pretty good with it. I’m not sure if it has any synchros or not. He has had both knees replaced too but gets along well with it.
Locally found a 2001 John Jeere 4700 with less than 200 hours on it AND is hydrostatic. Asking over 30K for it and looking at them on-line seems to be waaaaay to much.
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
