High Brook Hills
Bronze Member
- Joined
- Oct 13, 2011
- Messages
- 66
- Tractor
- Case Farmall IH 60
Family has one 2008 JD 6430, two neighbors (people living within two miles) also have one each. For the past 18 or so months each of these machines have experienced the exact same problem at the exact same time. They are all 2008 model years, MFWD, Diesels, four wheels, with FEL and range from about 400 to 900 hours on the clocks.
All problems have required a diagnostic test to determine what was wrong. Some of the problems have been corrected by the diagnostic tool.
Currently, all three tractors are showing to be overheating when the FEL is under a load above about 100 pounds. All three tractor's temperature gauges show to be well within the middle or lower of the temperature range.
All three farms started talking recently and comparing notes. The same dealer is servicing the machines, costs are almost the same for the repairs, all the breakdowns are the same, all breakdowns require a diagnostic tool to identify.
Now all three families are very upset with their Deeres and are looking to get rid of the machines.
Is there anyway the breakdowns could have been programmed into the machines? Could an error code have been sent directly to the equipment without having to plug into the diagnostic port? They are all used for basic chores, mowing, running balers, etc on properties in the 100 to 200 acre range. It is strange that all three machines with different hours have the same breakdowns in the same time frames.
On a related question, is there an inexpensive diagnostic tool available for these machines?
