Tires Unloading Tires - Questions?
   / Unloading Tires - Questions? #1
Neophyte
Platinum Member
ME
John Deere 3320 eHydro with 300CX FEL
Is it possible to unload loaded tires? If so, how would you go about doing it?
   / Unloading Tires - Questions? #2
Just wondering..
Why would you?
I ask because many used tractors that I look at have loaded tires and I would rather not have them. I would rather use a rear weight/ballast for loader use and be able to remove the extra weight (loader and rear ballast) for finish mowing. You don't have this luxury with loaded tires.
   / Unloading Tires - Questions? #4
When I bought my tractor I paid extra for loaded tires and thought they were a good thing. Now I am planning to unload them the first time I have a a flat which requires a service truck. Why you ask? For one thing it's not easy to lower pressure unless the solution is below the valve stem - that exposes the interior of the rim to oxygen which can lead to corrosion. The fill also reduces the tires ability to flex which reduces traction. Filled tires are so heavy they are nearly impossible to change or work with by yourself unless you buy some special equipment or a hoist. Lastly, if you have a situation where you don't want the weight (soft soil, avoidance of soil compaction, etc) you are simply out of luck.
   / Unloading Tires - Questions? #5
You should be able to drain most of the loading solution out of the valve stem. Otherwise you can also break the bead.
You will also have to contain and dispose of the solution.
Egon
   / Unloading Tires - Questions? #6
Yeah, but without rinsing the inside of the tire and rim well the leftover solution is likely to cause corrosion. For peace of mind I'd like to take the tire off the rim. Not so hard with the right tools, but I probably don't have enough air to reseat the bead on reinflation even with a band around the tread.
   / Unloading Tires - Questions? #8
I asked my dealer about loading tires and he said a lot of people are putting in used anti-freeze instead of coolant. I would not think that would be as bad to get out as the calcium stuff.
   / Unloading Tires - Questions? #9
The anti-freeze isn't corrosive, but it is toxic. I wouldn't like to leak large quantities onto the ground and have it seep into the water table.
   / Unloading Tires - Questions? #10
They do have non toxic antifreeze now. And from my pricing it costs about the same as using calcium chloride. Not as heavy though.
UNUSED AGT MCMRT14 STAND ON SKID STEER (A51243)
UNUSED AGT MCMRT14...
2003 PETERBILT PB 330 WATER TRUCK (A51243)
2003 PETERBILT PB...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
6' DISC HARROW (A51243)
6' DISC HARROW...
UNUSED AGT SAWMILL (A51244)
UNUSED AGT SAWMILL...
Commercial Trailer (A51692)
Commercial Trailer...
