fitterski
- Joined
- Oct 20, 2016
- Messages
- 377
- Location
- Nouvelle, QC
- Tractor
- 1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
I was getting only 12 system voltage so suspecting a burnt alternator diode I installed a new alternator that was on hand ...to no avail. Seeing that I was unable to finish the TS I thought I should get some advice. The host is a Cat-426 w. a Perkins diesel. One of the alternator connections is "D+" the (309-GY) wire to which on the attached diagram comes form the Start/Run key and passes through a resistor and a diode.
There is NO charge light but there is a completely independent voltmeter. I suspect that the (possibly 2 watt) resistor and diode protect the probably digital innards in the alternator. When system voltage is high enough, juice gets through to BLOCK field power, when the voltage drops it isn't enough to prevent charging so it goes to maybe 14vdc. The thing is that I don't really KNOW that this is so, I'm only guessing.
What would be the next step(s)? Test for a resistor/diode/wire failure by bypassing 12v power through a 2 watt bulb to the D+ terminal and see what it does to charging? If that works then next test just for a resistor failure via the same drill but only across the resistor leaving the diode alone? I don't wanna blow the alternator.
TIA
TIA
