Unexplained Traces in The Snow
   / Unexplained Traces in The Snow #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
This thread is specific to a certain recent incident, but is also general. The other day I backed our JD 6200 out of the barn to blow snow. It has been cold here. At time minus 35C in the mornings. The tractor was plugged in (coolant heater only) for a couple of hours. Started but didn't sound happy about it!
I lifted the bucket boom to avoid an obstacle where it was parked and backed out maybe twenty feet and turned sharply. Then I noticed a trail of hydraulic fluid in the arc where I had turned and went to invesigate. The only thing I could see was what looked like a drip on the bucket cylinder on the one side but I never even activated the bucket. And only raised the boom inside the building.
Now that I think about it. Maybe it came from the steering cylinder mounted latitudinaly (sp?) across the front underside. anyway, I carefully observed the snow during my subsequent snow removal operations but noted nothing amiss.
Has anyone experienced any cold seal failures upon initial operation of hydraulic equipment?
In general, for years, I always seem to come accross either hydraulic oil in the snow or totally unexplained coolant traces in the snow where no equipment or vehicles ever seem to show a loss of such fluid. It's hard to say if such things are happening year round, as one would never see the evidence.
   / Unexplained Traces in The Snow #2
You may want to keep a close eye on the hydraulic fluid level. If you are seeing traces as you operate, you most likely have a leak. It may not be a bad leak but it is there. The best way to find a leak I have found is to look for a wet spot that collects dust. The usually show up around seals, the wipers on the hydraulic cylinders, and gaskets.
I have operated equipment in colder temps than you describe without leaks. The coldest I personally have operated has been -42 to -45C without leaks. There is a significant amount of warm up time though.
   / Unexplained Traces in The Snow #3
I have had times when the snow has messed with my steering lines and moved them just enough to leak a bit as they drag on the crusty snow. Seems that they only work loose in the winter.... I have a couple of coolant heaters on mine....and it stays plugged in all night in this weather..
   / Unexplained Traces in The Snow #4
...........Has anyone experienced any cold seal failures upon initial operation of hydraulic equipment?...........
Yes. Many years ago in the 70s we were out trying to salvage a power line. It was storming and very cold but our idiot foreman decided abusing the digger truck (and us) was a good idea. :rolleyes: We set up at the first pole and I pulled the control lever to raise the boom...nothing happened for a second or two then it very very slowly began to rise and as it did so hydraulic fluid came past the seal on the piston rod but since it was was so cold it had the consistency of grease.
We did make an honest effort to salvage the line but it just wasn't possible; we packed up and headed back in to town.
   / Unexplained Traces in The Snow #5
now THAT'S COLD!!:snowflake::snowflake::snowflake::snowflake:
That's what it looked like, grease! The JD has a closed hydraulic system, so the oil doesn't warm up with the tractor idling. They had installed OEM a heating element in the air space of the transmission but these tended to burn out, so I actually disconnected mine from the block heater. These German engineers need to have their earrings ripped out and then best be FIRED!
   / Unexplained Traces in The Snow #7
I often believe that the engineers never actually use what they design! They should be made to do a years maintenance on any machine, changing filters, lubricants etc, outside in the cold!
What kills me, is when they came out with this tractor, they proclaimed "We started with a clean sheet of paper" How STUPID! If you try and actually find out about products and how they work, it's almost impossible! Everything is marketing driven targeted at your average mindless consumer. Or the cost is not even mentioned, just the bi-weekly payment amount! There are pickup trucks being made where you need to raise the cab to get at the spark plugs. Who investigates such things before buying? Shouldn't Motor Trend and the like, figure stuff like this into their evaluations? No, but it's got twelve Big Gulp Cup Holders and storage pouches on the seat backs WITH BUCKLES! Great for when your driving and trying to get something out!
I need to go outside and cool off! I'll stare at the grease smear in the snow for a while!
   / Unexplained Traces in The Snow #9
Interesting. You might check your lift cylinders for scoring where some of the fluid might be coming out. Don't use your hand though, get a chunk of white cardstock and hold it near the lines and cylinders with the engine running and as close to the same operating conditions that caused the leak traces. Using your hand is a good way to get hydraulic fluid injected into you, and that's absolutely zero fun.
   / Unexplained Traces in The Snow #10
At -31 degrees F (-35C converted), yes you could of had a temporary seal failure. I have been around a lot of construction equipment at -15F where the first few moves on the cylinders leaked, until the seals reset once they warmed up a bit. At very cold temperatures, everything shrinks (get your mind out of the gutter boys) and takes a bit to expand. I suspect if you look up your cylinder specifications, you will probably see your outside the specified operating range until the fluid warms up.
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
CAT D3 LGP (A50123)
CAT D3 LGP (A50123)
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A51692)
2006 Ford F-550...
