Understanding tire sizes
   / Understanding tire sizes #1
Anonymous Poster
Epic Contributor
I need some info on understanding what tires sizes mean. Is there a good tire site that actually explains the numbers, or is it manufacturer specific?
In particular, my Ford 2120 manual specifies the following for turf tires:
front - 27-8.5-15
rear - 18.4-16.1
What does this mean?
Thanks.
GregM
   / Understanding tire sizes #2
gmccarty
In the case of your tires:
front - 27" is the overall height of tire
8.5" is the tread width
15" is the wheel diameter
rear - 18.4" is the tread width
16.1" is the wheel diameter
Are you 2WD or 4WD?
Lewis
   / Understanding tire sizes #3
Call me dumb, call me stupid, but why do they rate the front tire different from tha back. Why not just have the same ratings, each number meaning the same thing?
Murph
   / Understanding tire sizes #6
Excellent sites for looking at various tire types and sizes.
Lewis,
Since the rear wheel values don't have a height, and the front's do, does this mean all rear wheels are the same height?
And for the front tire, the height is measured from the center of the wheel, correct?
Thanks.
GregM
Ok, the more I think and look into this, the more confused I get. Here are the recommended tire sizes from the owners manual.
Ag -
rear: 14.9-26
front: 9.5-16
Turf -
rear: 18.4-16.1
front: 27-8.5-15
So, if I understand this correctly, the rear wheel (rim) of the Ag's are 10" larger than the turfs, the front wheel of the Ag's are 1" larger than the turfs.
Am I reading this right?
GregM
Not real important, but I just wanted to add...
The rubber part is called the tire... an usually the metal part is called the rim. And the assembly together is called a wheel.
Not just in tractors, buy autos too.
Ken H.
   / Understanding tire sizes #10
The best thing, is to start with a base comparison of the tires you have. If you could provide the manufacture, then we can research the tire data in the web sites I noted before, or find the correct manufacturer.
Ok, now for the Ag tires you mention. That particular ag tire uses a much larger diameter rim than the turf's. It will have a fairly short sidewall, and has a somewhat narrow tread. You can probably get an Ag tire that runs on a 16" rim; It will have a big sidewall, will be a wider tread, and be more "balloony" for lack of a better word. The front Ag's are a bit wider than the turf, and do use a slightly larger diameter rim.
The turf tires now, they are more balloony. They are a floatation tire, and tend to be wider than Ag or R4 tires. They sperad the weight over a larger surface area, so there is less impact on grass. In the case of my Kubota, I use 16" rims for both turf and R4. But, the rim for the Turf is wider, because the tire is wider and needs the wider rim to properly support the bead and sidewall.
The important thing is that each tire is ratio matched to the gearing of your tractor. Unlike a 4x4 pickup, which uses the same size tire, and same gear ratio front and rear, the tractor uses a different size tire fron and rear. To adjust the geartrain, they have different differential gearing front and rear. The rolling diameter of the tire has to match with the gearing of the tractor, or else you will overload the axles and driveline and it will break.
So...
Your 14.9-26 rear ag tire uses a 26" rim, recomended width of 13". It has an overall tire width of 14.9". Overall diameter is 52". See http://www.firestoneag.com/tiredata/bias/rtr_tfr.asp
I tried to look up the front tire size at Firestone, but did not see a front ag.
I'll see if I can look the other tire sizes up later, or you can look. Between the Firestone and Goodyear sites you should be able to find the proper size tires and spec. I have to do a report for school... so I will look later....
2022 AIRMAN SDG25  GENERATOR (A45046)
2022 AIRMAN SDG25...
New/Unused H15R Mini Excavator (A44391)
New/Unused H15R...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A43003)
2015 FREIGHTLINER...
Homemade 16' 2 Axle Trailer (A44502)
Homemade 16' 2...
2017 ADDCO ROAD SIGN DH1000-ALS (A45046)
2017 ADDCO ROAD...
Land Pride Commander Series 2 (A44501)
Land Pride...
