I hope I don't speak out of turn here. We have old LX mowers out that are 10-12 years old that have never required anything but belts and batteries. I personally have a
late model LX176 that is in excellent condition and last year I replaced the hydrostat fan, input shaft sheave, hydrostat drive belt, primary and secondary deck drive belt, both deck spindles and both drive idlers. The mowing conditions were extremely dusty and all the parts that required replacement were the parts that were most exposed to the dirt. I also have a 2004 L100 that will need drive belts after only one year of use. The longevity of the mowers that you have mentioned is based on the thickness of the metal in the deck, frame, front axle, etc. The bearings in the mower deck on the L100 series are slightly smaller than the bearings on LTs and LXs. The other significant difference is that the LTs and LX series mowers are built or assembled in the John Deere Horicon plant and the L100 series mowers are built by Scotts, as were their predecessors (Sabre). I hope this kind of clears things a little. Bottom line is that with proper care and maintenance, and realizing that deck bearings don't last forever, even a "low end" L100 will outlast most of the department store branded mowers.
