Underground Electrical Service Question
   / Underground Electrical Service Question #1
Believer
When I run an entrance conductor underground in conduit, should I come directly up out of the ground on either end or is there supposed to be some kind of "loop" to allow for settling of the ground? I have a meter on the transformer pole and I run from there underground 180 feet to the house breaker box.
   / Underground Electrical Service Question #3
Believer, It would be nice to know where this is being done??? Rules/Codes can change from State to State & County to County.... The NEC allows the AHJ a lot of lead way as the Power to Be..... Sometimes the Power Co has a Spec when your wiring a meter....
   / Underground Electrical Service Question #4
They also make slip couplings to allow about 4" of movement up or downs as the ground settles/heaves. They are code in NH.
   / Underground Electrical Service Question #5
The captaincrab is right, and while he's looking at it from a code and the Authority Having Jurisdiction point of view, you'll also want to ask around to see what is done locally. New Hampshire needs the slip couplings, they are not used here in North Carolina (as an example). Definitely talk to your power company.
No matter where you are, I'd be sure the soil that the conduit lies on near the ends of the run (about 10' or so) is undisturbed or compacted or has pea gravel fill so that the pipe won't move.
Pete
   / Underground Electrical Service Question #6
Same here in Jefferson County, WV
   / Underground Electrical Service Question #7
Here's how our underground electrical wire runs from the transformer to the house. We will have a service panel mounted to the 6x6 posts that will have disconnects so that I can shut off all power to the house from the outside without having to remove the electric meter. The service panel will contain a 400A meter and 2 200A breakers. There are 2 200A breakers and two conduits because we are running 2 200A lines to the house, one for the basement and the other for the rest of the house.
There are more pictures at this link.
Obed
   / Underground Electrical Service Question #8
Here in the Berkshires, the service conduit are specified with two 90 degree bends on each end...and speaking of specifications, they should be in written form from the local power utility/provider.
For our house project, we received drawings and engineered spec's from the power company. Obviously, the drawings detailed both ends of the run -- the pole end and the transformer end. This specifically addresses getting power from your nearest pole to an underground transformer, however.
The service entrance run -- from the underground transformer to the house itself -- should be handled the same way. The ends of the conduit should have some form of arced bend in them.
By the way, if the source end of either run is exposed -- pole to transformer or pole to house (I'm not really sure about your situation) -- you have to consider the possibility of water entering the conduit and freezing. Needless to say, this can cause breakage due to heaving. I'm not sure where you are, but you may want to ask your electrician about this.
Have a good one,
Red
   / Underground Electrical Service Question #9
My brother in law (who is an electrician) put in my electrical service, with me getting in the way. In MN a frost loop is required, but he said nothing about the slip joint others are referring to, but that may have changed by code since he put mine in.
   / Underground Electrical Service Question #10
My service entrance conduit had to be "below" 5 feet, or "over" 5 feet deep. It had to have a pull box every 100' and mine was 220 feet to the pole so I had two. The 90s at the ends are long radius sweeps. All above ground service entrance conduit must be either schedule 80 PVC or rigid metal conduit. No EMT thinwall metal conduit. No EMT below grade in the ground. So, the main runs can be sch 40 but must switch to heavier grade where they turn up. My utility wanted a pull rope installed and some even want the official thing (can't remember the name) pulled through to prove the conduit is clear. At approximately one foot above the conduit an official 6" wide red caution tape must be run to warm of the conduits location. If the ditch is to be used for other lines, like water for instance, they should or must be at least one foot apart.
All this is for the main service conduits. The secondary conduits that run to sub panels or from the meter to the house, can be at 24 inches. But mine are deeper because they run with water lines and I needed at least three feet for those to prevent freezing.
Always run a big enough size! Larger means a much easier pull, less chance for wire damage and the chance to get another wire through if needed. Bigger is better!
I was concerned about settling and stress on the box so I just filled it slowly and washed it in with water to compact it without downward pressure. No other special design was used. We don't get heaving here and the initial settling was handled by washing it in for compaction. The conduit comes up to a male thread coupling and a nut in the box.
You also can't have more than 270 degrees of bends in each run of conduit. But the casual bending in the ditch doesn't count.
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2010 American LaFrance Condor MRL Long Line Tri-Axle Thermoplastic Striping Truck (A52377)
2010 American...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
16FT flat bed trailer (A53424)
16FT flat bed...
