Mechanos
Veteran Member
It's pretty easy to get most of the liquid fill in tires out of the tire. What little tips or tricks have you used to get the last little bit of liquid out once the level has dropped to the level of the valve stem? Break the bead? Any other bright ideas?
I was going to stick some small plastic tubing down the valve stem hole and suck the remaining liquid out with either a siphon or vacuum. I'm trying not to break the bead since this set of tire is a bear to get the bead seated again.
