Ultra Cab II Parts and Notes
   / Ultra Cab II Parts and Notes #1
Sportsman762
Platinum Member
The Ultra Cab II is used on the M95, M96, M105, M108, M4900, M5700, M6800, M8200, M9000 tractors. Here are a few things I have found out about them.
The front 34070-71130 wiper is a 17" j hook style front wiper that is common to many vehicles these days. Some wipers will hit the arm, so you might have to bend the arm slightly for clearance.
The 3n300-52870 gas strut for the door utilizes standard 10mm ball ends and are 11" long when extended. I bought a 72 lb version but if I did it again I would go with a heavier unit. It was terrible getting the old ones off. I had to grind the ends off the strut to get them free from the balls. I think this is why Kubota includes the balls on the replacement struts.
The Ultra Cab II cup holders are too shallow. They can't hold any bottle or cup without dumping it. I discovered that on the smaller side of the 3A751-74180 cup holder a Seachoice 79481 3" cup holder is a press fit into the kubota cup holder extending it enough to make it a usable. No screws needed, just push it in, and good luck on getting it out! They cost around $6 online so its a very cheap upgrade. I am still looking on a solution for the larger cup holder.
The 3N300-75754 cloth suspension seat is a Grammer DS85H/90 and is used on the M96, M105, M108, MM5040, M5140, M6040, M6060, M7040, M7060, M8540, M8560, M9540, M9960, M4-071, M6S-111 tractors.
The cloth bottom cushion Kubota 3n300-85020 is Grammer # 127123. The cloth back cushion Kubota 3n300-85030 is Grammer # 132794. The cushions run around $120 each online compared to Kubota's $350 each or $2200 for the complete seat.
Hope these random notes help someone.
Year: 2015 Make: Peterbilt Model: 320 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2015 Make...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
Chery 7' 20 Drawer Workbench (A50121)
Chery 7' 20 Drawer...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50322)
2013 Vermeer V800...
Swict Q.A 60" Bucket (A50121)
Swict Q.A 60"...
HD Bin Dump Forks (A50120)
HD Bin Dump Forks...
