uh oh...the tractor ate my grease gun
   / uh oh...the tractor ate my grease gun #1
Central VA
Kubota B7510
Well, the tractor won't let go at least. I'm using a new pistol pump manual grease gun for the first time. Yes, can you believe my tractor only has 11 hours on it after 4 months of use. Anyway, this is my first time using a grease gun ever.
I first tried greasing a couple of zerks on the 3pt hitch and was successful. Then I moved onto the loader. It's an Kubota LA302 loader (just because I don't know of all loaders are built the same way) and I was attempting to grease the pivot point on left side, near the top of the loader at the rear (near the operator). To access the zerk, you need to go through a hole in the loader frame. So I push the gun onto the zerk. It needed a little force for some reason but that didn't worry me because the gun didn't slip onto any of the other zerks easily either.
Now I can't get it off no matter how I pull and twist. Can anyone give me advice? If the solution is obvious, forgive my lack of tractor experience /forums/images/graemlins/crazy.gif
Thanks.
   / uh oh...the tractor ate my grease gun #2
When problems like this arise, the old adage of "don't force it, get a bigger hammer" apply. The fitting on the end of the grease gun is new and probably just slightly tighter than it should be. I would just exert more force and it should fall off then. I could give you a "smart Aleck answer" and suggest that you grease it, but I guess that it might not go over too well this morning. I know how frustrating a simple thing such as this can be. The worse that can happen is that the hose will bread and then you will need to use a pair of needle nose vice grips to grab it and pull. Hopefully that won't happen. If there is any way to get a small screwdriver between the nipple and the hose end, you can pry it loose. I have had this happen in the past and have never broken anything by brute force being applied. That is either because I didn't have enough brute force to use or the hose gave up before I damaged anything. Sometimes you are in a position where there is no alternative to brute force and I believe that this is going to be one of those occassions........ Junk...
   / uh oh...the tractor ate my grease gun #3
Junk has given you some good advice. I have had that same problem and on one occasion I even pulled the Zerk fitting out when I pulled sharply on the grease gun hose. My wife was standing close by and heard me curse and asked me what was wrong. When I explained to her that the hose was locked into the Zerk fitting she told me to turn the water hose on it.......... /forums/images/graemlins/grin.gif I really don't think that's a feasible solution however.
Thanks Junk & Pine. I don't have the hose on the business end of the gun but a solid metal barrel. I'll give it another tug when I get home. I was afraid of yanking the zerk off, but I guess I could figure out how to fix it. I was also afraid of pulling so hard, breaking the gun or zerk, falling backward with grease flying everywhere in the garage and then having to explain why I didn't change out of my "job" clothes before I decide to grease the tractor. /forums/images/graemlins/laugh.gif
MT
   / uh oh...the tractor ate my grease gun #5
Use a screwdriver (flat blade) to lever the nose of the gun away from the loader frame/zerk.
Soundguy
   / uh oh...the tractor ate my grease gun #6
There are two types of Zerk fitting now days that look alike. One is just tapped into a drilled hole and the other is threaded into the tapped hole. I have also seen some that are designed to cut their own new threads when being inserted. If the Zerk pulls out, it isn't the end of the world. If it is tapped, then you will just need to get a replacement and hope that the threads aren't damaged. If the threads are damaged, it is easy to repair them or you could use one of the "drive in" Zerk's. This is a time issue, not a difficult one. There isn't the worry of damage by rethreading like there would be with a part on an engine. The worse thing that can happen is that it will require some disassembly to get to it, but that end of the tractor isn't rocket science, so the average home owner can do it without much difficulty with standard tools. Just remember we are here for you if you need us and we can walk you through any difficulty given enough time. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
PS... before I forget, the tractor manufacturers use either Metric or USS threads for the Zerk's, depending on the brand and where it is manufactured. You might have to remove a good one to know which it is, or ask the dealer. He will probably just give you one to replace it with.....
   / uh oh...the tractor ate my grease gun #7
</font><font color="blue" class="small">( why I didn't change out of my "job" clothes before I decide to grease the tractor.
)</font>
i always make sure to change into my job clothes before i grease anything /forums/images/graemlins/grin.gif, of course i pretty much always wear work clothes, my gf cant understand why everywheres we go i wear dickies work pants, i tell he there comftorable and ya never know when your gona get dirty, like when your driving along and happen to see the perfect old greasy whatever at a tag sale, cant run home and change into work clothes!
   / uh oh...the tractor ate my grease gun #8
That is how I lost a very wonderful girl friend over 35 years ago and I have never forgotten it. Now I know better... I carry a jump suit in the trunk... Remember the old advertising slogan, "clothes make the man"??????
   / uh oh...the tractor ate my grease gun #9
"I could give you a "smart Aleck answer" and suggest that you grease it"
Junkman...you slay me. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Another alternative may be to actuate the cylinder the zerk is attached to. This may relieve sufficient pressure from the grease to allow the gun to be removed.
BE CAREFUL - The zerk may rotate out of the area of the hole in the loader frame. The zerk could break if it goes too far.
That would solve the first problem... /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / uh oh...the tractor ate my grease gun #10
</font><font color="blue" class="small">( That is how I lost a very wonderful girl friend over 35 years ago and I have never forgotten it. )</font>
yea luckly my gf doesnt mind getting greasy as long as she is dressed for it, when we first met i hadnt thought she would ever have any interest in anything country or tractor related, she had lived in suburbia and never been on a tractor in her life, but she did like animals, works for a vet office, so she realy liked the goats and ducks, and much to my surprise has taken a real interest in learning about all the metalworking and fixing type stuff i do, like she was the one who did alot of the grinding on my root rake parts, and when it came time to get the giant dent outa the half inch thick plate on the top of the dozer she was more than willing to hold the oxyacetalene torch on the front side while i held our huge propane torch on the back side and then i would beat the heck outa it with the hammer, took a few times but got it nice and straight so could weld on my mounting brackets, it sure was nice tho to have a helper rather than trying to set down the oxacetelene torch everytime
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2005 JLG 660SJ TELESCOPIC MANLIFT (A52705)
2005 JLG 660SJ...
