I recently had a county water line run down our driveway (1400ft) to our build site, and I installed yard hydrants along the way. The hydrant at the very end is the only one we've used very much; the rest are primarily for fire protection if the woods along the road catch fire.
One blessing (?) of the county water is nice high pressure, about 125# at the last hydrant. So apparently, the high pressure on the valve at the bottom of the hydrant riser is too much for the design of my hydrants (Simmons). The riser rod slipped under the adjustment setscrew making the hydrant leak, so I readjusted it and retightened the adjustment setscrew, which solved the leak for about a week. On the second re-adjustment, I must have over-tightened the setscrew, because it is now stripped! Actually, the brass "connector" is stripped; the steel setscrew is fine. Simmons will sell me a replacement brass "connector" ($9!!!), but with the high pressure, I think the problem will just reoccur. They don't make a replacement part in steel.
Any fix ideas short of replacing all six hydrants?
I was thinking about trying a heli-coil in the brass connector, but do they make them that small? The setscrew thread is about 1/4-20, and there's only about 1/4" of meat in the brass for thread.
- Jay
- Jay
