Ugh, leaking front axle L3800
   / Ugh, leaking front axle L3800 #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
I noticed some wetness on the inside of my left front tire. I did some checking and it looks like I have a leaking seal. Fortunately, I have the shop manual, so repair shouldn't be difficult. It's just caught me at a bad time, with the holidays and moving. I might end up having to let the local Kubota shop fix it, due to my time constraints. Anyone make this repair already? How much time and effort will it take me?
   / Ugh, leaking front axle L3800 #3
Holidays and moving? Not using the tractor much. Unless it's leaking a gallon a day, what's the hurry? Stuff a rag inside the wheel and wait for better days. A leaking seal isn't exactly life threatening. It won't hurt to jack up the culprit wheel and shake the tire a bit to make sure it isn't a deeper problem than a seal, then see what happens with the leak.
   / Ugh, leaking front axle L3800 #4
Look carefully at the seal. There may be grass or other stringy debris caught up in the seal interface. Clean that crap out!
It happened to me on a front axle. I was happy that the leackage stopped with no other attention but inspection and removal of foriegn material.
Of course, the stuff I pulled out was multiple 4 inch lengths of grass, but.......;-)
Actually, I'll be using it a fair amount to facilitate the move. I need it to load some implements, steel pipe, welding tables for my shop etc. Not a lot of hours, though, so I can deal with the leakage for now.
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
202479 (A54757)
202479 (A54757)
2013 International WorkStar 7400 Altec D3060ATR Insulated Digger Derrick Truck (A55973)
2013 International...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
