TZ25DA Electrical problem
   / TZ25DA Electrical problem #1
Byusda
Spotsylvania, VA
TZ25DA
Working fine then would not start. New battery and good voltage. Starter wont even turn over. Checked all safety relays and they are good. When I jump female socket of Safety Seitch Relay the starter turns over but will not start. Have good grounds. Any ideas
   / TZ25DA Electrical problem #2
Welcome to TractorByNet!
I moved your thread to the New Holland Owning & Operating forum. :)
   / TZ25DA Electrical problem #3
Are you getting power put of the key switch? Power to the starter?
   / TZ25DA Electrical problem #5
The symptom sounds as though one or more of the safety interlock switches has not been satisfied or is defective. Generally they're on the seat, PTO, clutch, HST treadle, etc. If all are satisfied and good there may also be an operator presence control (OPC) on your tractor.
   / TZ25DA Electrical problem #6
I assume you have checked that fuse #2 hasn't blown
2023 Electric Intimidator (A50514)
2023 Electric...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2012 Ram 3500 Crew Cab S/A Mason Dump Truck (A50323)
2012 Ram 3500 Crew...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
(2) Ford Suitcase Weights (A50515)
(2) Ford Suitcase...
