TZ25DA couple questions
   / TZ25DA couple questions #1
sledstew
North Dakota
Hew Holland TZ25DA
New guy here to the forum before I get started Id like to say thanks in advance for any info and help:
A couple things with my TZ25DA:
1) Hydrostatic creep , seems almost like the pedals are sticking but I took it to the dealer and they were not very helpful, is there an adjustment on the pedals somewhere that I can make to stop it from creeping on me?
2) Initial startup for the day, when I go to start the motor for the first time it seems like it crankls a long time before it fires, after initial startup it starts real easy. Im leaning toward the glow plugs on this one, how do I test them to verify they are working correctly. I havent located a manual yet but thats on my list.
   / TZ25DA couple questions #2
Does it crank after you've let the glow plugs cycle?
   / TZ25DA couple questions #3
Probably a dumb question, but did you grease the pedals? Are you sure it is creeping and not just rolling like being in neutral? Mine will roll pretty easily when I let off the pedals, but you can tell it is not creeping.
As for starting, I have not worked on tractors much, but I have a lot of knowledge on automobiles. Do our tractors have a check valve to stop the fuel from draining back to the tank while sitting? I have had vehicles where the check will go bad and after sitting for a while it will take extra cranking to get it started, unless you cycle the key a few times to pressurize the system.
Hopefully someone will be more help with this.
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
2015 INTERNATIONAL PROSTAR (A53843)
2015 INTERNATIONAL...
John Deere 6120E (A50323)
John Deere 6120E...
2009 40ft High Cube Refrigerated Storage Container (A51691)
2009 40ft High...
John Deere 310A Loader Backhoe (A52384)
John Deere 310A...
