TZ25DA 4x4 -shuts off after an hour-ish
   / TZ25DA 4x4 -shuts off after an hour-ish #1
rrasi
still in shopping mode
Hello all!
I've been having this problem and I was trying to pin down the exact conditions of when this happens. Now it has become a bit more frequent.
After about an hour of mowing the grass, my New Holland TZ25DA sometimes starts to sputter and then chokes off.
Sometimes I can start it right back up and sometimes I need to let it sit for 30 minutes. The temperature reads normal and all fluid levels are ok. It acts like it is starving for fuel but of course, there is plenty of gas. At first I thought it happened more frequent when I was on one of my (steep) hills, but now I'm not sure.
ANY help or suggestions would be appreciated. And I can repay with my own political comments:laughing:
Thanks, Jeremy
   / TZ25DA 4x4 -shuts off after an hour-ish #2
Could be there is trash in the fuel tank or it could be the vented fuel tank cap is plugged. Loosen the cap a little and see if that helps.
2020 KUBOTA RTV...
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
UNUSED LANDHONOR RGB-11-72W - 72" ROCK GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
30051 (A53424)
30051 (A53424)
