TZ24DA Transmission
   / TZ24DA Transmission #1
CDN24
Sudbury Ontario
NH TZ25DA
My transmission casing is shattered; all cracked up; not repairable. The tractor is fine; I need a transmission for it.
Does anyone have a lead on where to start looking for a replacement?
I've tried and got nowhere.
   / TZ24DA Transmission #2
Tractor Tech, thanks
I went there; so far it's looking like tractors, attachments etc. I sent a request; fingers crossed.
It's a great little tractor I'd rather put it back into service than ...parts tractor.
   / TZ24DA Transmission #4
I’m going through the same thing on my TZ18DA. I found oil coming out and there is a crack on the top right of the case.
If you read the comments on the YouTube video, it ended up leaking again.
Hi mark
I'm thinking you don't want to be in my situation with the transmission.
If you can find a really good cast iron welder you might have a chance at repairing it.
My situation; two handfuls cast iron chunks on the floor. I need a transmission; can't find one.
Good luck
2014 PETERBILT 386 DAY CAB (A54607)
2014 PETERBILT 386...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
CASE TR310 SKID STEER (A52705)
CASE TR310 SKID...
378811 (A51573)
378811 (A51573)
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
