TZ18DA
   / TZ18DA #1
Kstocks
New Holland TZ18DA
I own a tz18da that is blowing white smoke from exhaust and running rough anty ideas
   / TZ18DA #2
White smoke usually indicates the presence of water. It could be a bad head gasket, cracked head, or just water in the fuel. More guesses may follow but you didn't really give much information. If you only get white smoke when you first start the engine it can be just cold.
   / TZ18DA
It blows white smoke all the time and doesn't have much power.
   / TZ18DA #4
Get it running and smoking..
Now, 1x 1 loosen the line from the pump to the injector AT THE INJECTOR..
Look at the exhaust, did the smoke change.?? IF NOT, retighten the line and move to another.. all the while looking at the smoke..
If u find 1 where the smoke disappears, u found the faulty cyl..
U can swap the injector to another hole and do the test again..
If the problem followed the injector, there ya go.. bad injector..
If it stayed on the same hole, ya gotta dig deeper..
It could b a pump problem, a bad valve in the head, a blown head gasket, or even bad piston rings..??
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
Electric Mobility Scooter (A51694)
Electric Mobility...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
(3) Rolls of New Barb Wire (A50515)
(3) Rolls of New...
