Typical Hydraulic Pump System Diagram
   / Typical Hydraulic Pump System Diagram #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
I am all over the map tonight but I would like to get a better understanding of what components are required/recommended in a typical closed hydraulic system.
Specifically installing a 20GPM rear PTO pump to drive a FEL mounted hydraulic auger with forward and reverse? TIA
   / Typical Hydraulic Pump System Diagram #2
I don't think you mean closed center system for which you would need variable delivery pump with a pressure controller.
I think you need open center system for its simplicity. If your pump is constant delivery pump then you need an open center motor control valve.
I bet some of the hydraulic gurus will chime in with more specific advice.
I'm sure I would have spelled hydrolic wrong if I hadn't looked it up. :eek: Thinking about a PTO pump, a tank, some filters, a couple check valves and a in/out lever. In this case a picture would help me understand where everything goes and then I could work up the specifications.
   / Typical Hydraulic Pump System Diagram #4
Your tractor is open center.
First you need to know the PTO HP so you can match up a PTO pump. like these.
Your PTO HP is about 35. Maybe this one.
http://www.surpluscenter.com/item.asp?item=9-1047-1-C&catname=hydraulic
Surplus Center
You then need a valve or set of valves, with one of the valves a motor spool valve for the auger, a 21 gal tank, filter, and hoses.
Although the hyd fluid is only used by the auger, it is still an open center hyd system. The flow is pump to valve, to motor, filter, tank.
Your PTO HP is about 35.Maybe this one.
Good call JJ - PTO HP was dead-on and that was the exact pump I was looking at. So how do you control the augers rotation? I assume you need to change the direction of flow through the auger drive but how? Thanks.
   / Typical Hydraulic Pump System Diagram #6
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
