Balazar
Bronze Member
- Joined
- Apr 10, 2019
- Messages
- 62
- Tractor
- N/A
Ok, I've been shopping around. I'm looking for a tractor with loader and backhoe around 50-60hp. I'm building a house and starting a homestead on a 40 acre plot in the Colorado Mountains. The elevation is 8,400' above sea level. I plan on making a driveway, installing a septic system, generally doing lots of dirt work, land clearing and moving materials. For a little background: I have worked on drilling rigs and at mines for a very long time. I have been a heavy equipment mechanic. I can fix stuff.
I have looked at Kioti, LS, and now TYM. I really like the TYM T574 with the Kukje A2300 turbo diesel motor. One of the draws for me is that it has mechanical fuel injection with very little computer control and an emissions system that is separate from engine management. The other tractor that I am considering is the slightly more expensive T554. It is essentially the same tractor with a Yanmar 4TNV86CT turbo diesel motor. The Yanmar is a little more compact so the hood is shorter and slopes down providing a little better view. It also has an ecu with fuel maps and common rail injection. The Yanmar has a hydraulic implement flow of 9.5 GPM compared to the Kukje's 7.66 GPM
I know that the common rail Yanmar should do a little better at my altitude of 8,400' than the Kukje. The question is how much better? Is it worth it for the little extra umpf and extra hydraulic flow? I have never operated equipment this small before. Will the hydraulic flow make a big difference on what implements I can use? Obviously it will be slower running the backhoe. If the answer is yes common rail will make a big difference, I will probably take a second look at Kioti and LS before making a decision.
Here is a link to the TYM site. There is a comparison of the specs of the two machines a little bit down the page.
T554
T554
