TYM Hydraulics
   / TYM Hydraulics #1
moveit
Fall City, Wash
TYM T293 (2009)
I have a TYM 293 Tractor and LITW 6" Hyd feed chipper. When I run the tractor at the designated PTO rpm and run the chipper feeder I get hyd oil spraying from the tractor filler cap. It seems to be pressure related - If I slow the tractor rpms it doesn't leak as much.
It was suggested that I use some form of expansion tank but I haven't found anything for hydraulics.
Anybody have experience or ideas on this subject
   / TYM Hydraulics #2
Look through these.
Surplus Center
You might also be generating bubbles which will cause the fluid to expand and some fluid to exit out the filler cap.
Check your suction hoses and re-tighten everything
   / TYM Hydraulics #3
What kind of hyd flow/ pressure does your tractor supply, and the chipper want?
Without knowing much, it sounds like one of the following:
1. as the first person mentioned, you have an air leak, sucking air into the suction side, creating bubbles in the fluid. Doesn't show up for casual use, but for this high-volume use it comes out.
2. You have too small a size hose (or connectors) on the return from the chipper, creating restriction/heat/ bubbling.
3. you are low on fluid, again creating bubbles.
4. The chipper is overworking your tractor pump, creating hot oil and - bubbles.
Compact tractor might be designed for occational hyd use, while the chipper feed is constant use. This is combining with several of the above, so as to get air flowing along with the oil, and it just builds upon itself.
On ag tractors, sometimes one needs to run a larger hose back to the oil filler cap and let the oil dump back to the tractor quickly, wthout quick connectors or other flow restrictions in the way - after the chipper is done with the oil, you want it to run with no restrictions at all easily and quickly to the tractor sump so it can cool and settle out air bubbles as quickly as possible. Aslo, many farm tractors allow an extra gallon or 2 to be put into the sump without harm, overfilling it but this allows the oil to stay cooler, not be recycled as quickly anf overheated.
Don't know how that last paragraph applies to a compact tractor, but just for ideas....
There is some ration of how much oil is in the sump, vs how much oil flow one can use for constant use - so the oil has time to sit and recover & cool down in your tractor sump. I suspect you are near or over that limit. Any of the above issues makes it worse.
--->Paul
   / TYM Hydraulics
Thanks for the input - I will check all of the points you made!
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
WB Mower (A50120)
WB Mower (A50120)
Ford Tractor (A50120)
Freightliner Tender Truck - Adams Tender (A53473)
Freightliner...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2016 WESTERN STAR 4900 HYDRO VAC (A53843)
2016 WESTERN STAR...
