TYM 723 hydraulics heat up using remote float
   / TYM 723 hydraulics heat up using remote float #1
cowridermi
Bronze Member
Addison, NY
MF 65, MF 1080, MF 1100, Kubuta B8200, Farmall 504, Farmall Cubs, Farmall Super A, Belarus 250AS's, Belarus 611, JD F935
I am using the float position on my remote when using a drum mower. The hydraulics heat up to the point that engaging gears is delayed. I have 700 hours on the tractor. My understanding of the valve is that the fluid should flow through the body the same as when in the neutral position so the fluid shouldn't heat up more that normal. The workshop manual shows the flow through the different positions. Is there an adjustment for the float? The manual doesn't show one.
Has anyone added a temperature gauge for the hydraulics?
   / TYM 723 hydraulics heat up using remote float #2
Are you sure you have a float function on the remote and not just a detent that holds the lever in place? Technically, it would give you the same effect as float, although the oil that should go on the opposite port is now getting forced to go through the relief valve and back to tank. This creates an insane amount of heat.
Both the parts and service manual show this as a floating detent.
Cylinder seems to float in this position. I went and attached a open hose on each port and started the tractor with it in float with no oil coming out. I may be chasing my tail with this. Need to set up a gauge to watch the temps. Engine stayed normal, just the hydraulic seemed hot.
John Deere 9620R Tractor (A53342)
John Deere 9620R...
LOT LOCATIONS (A52577)
John Deere X530 (A51573)
John Deere X530...
New Wolverine Push Blade (A53002)
New Wolverine Push...
Cat TH407C Telehandler (A53472)
Cat TH407C...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
