Tym 474 hydraulic top link
   / Tym 474 hydraulic top link #1
Red camp john
Tym t474 c
Just want some opinions on what hydraulic top link I should buy ? Looking to buy one appreciate any info . Thank you
   / Tym 474 hydraulic top link #2
The one that is between 20 1/2 to 31'' should be fine, I bought one that was somewhere between 18 - 26 and it is too short for my T474. I need to sell this to a T264 owner.
   / Tym 474 hydraulic top link #3
Also, if you have a quick hitch, you'll want one longer. Perhaps with a locking valve as well. The locking valve keeps the cylinder in place and takes the load off your hose and valve. A locking valve will also allow you to disconnect a remote and use it for something else while the locked cylinder stays in place. Nice if you have an extending or off-set attachment and need two remotes for that.
I have TnT but only use the Tilt cylinder when I'm using a blade. I use the Top cylinder every time I connect or disconnect an attachment and on the fly for my Flail Mower. With three remotes, I can still use two of them for a Ditch/Bank Mower.
Consider all the options. A locking cylinder is far less costly than adding another remote for special uses.
Thanks for info
Thanks for info
2018 FREIGHTLINER CASCADIA SLEEPER (A52576)
2018 FREIGHTLINER...
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
