TYM 454 showing double exclamation marks on dash
   / TYM 454 showing double exclamation marks on dash #1
stephencd1959
Duke, MO
TYM 454
Hey everyone.
Out in the back field mowing short while ago when I noticed that there were two black exclamation marks in black circles showing on the dash. Steady marks, not blinking. The one on the right would occasionally go out and the gear I was currently in would show. Then that would blink out and the exclamation mark would come up again.
Looked in the manual and nothing there that I could find about two marks showing on dash cluster.
Coming up on 95.3 hours so just a wee bit early for the 100 hr. regeneration cycle which is indicated by additional lights which are not showing. 50 hr. regen cycle was completed on time.
Fuel is new, air filter is clean.
Am I missing something stupid easy? That's the way I'm feeling at the moment. Any suggestions what this means?
Thank you
   / TYM 454 showing double exclamation marks on dash #2
If is is on the right side display it is the Exhaust Temp Lamp
This lamp is illuminated when the DPF temperature is over 400 degrees. I have never seen this on mine. I have removed the DPF so mine does not regen. You may have a bad display. Mine is bad so I can't hardly see it.
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
CONTACT INFO (A53084)
